Author Topic: done bushes - broken steering...  (Read 4231 times)
Offline javalin
« on: 06 March 2011, 16:05 »
Hello,
Changed wishbone bushes and anti-roll bar bushes - somewhere in the large amount of kicking with the subframe lowered to get things free I've broken the steering.  The steering wheel spins now freely - sounds like its come out of the steering rack somewhere/somehow?
Simple fix, or......?
Help appreciated...!!
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Re: done bushes - broken steering...
« Reply #1 on: 06 March 2011, 16:37 »
My guess is that it has come apart at the uj, check under the rubber boot in the engine bay and under the dash.
Offline javalin
« Reply #2 on: 06 March 2011, 16:40 »
ok ta - job for another day though.  Knackered now.
J
Offline AudiA8Quattro
« Reply #3 on: 06 March 2011, 19:41 »
UJ disconnected as already stated.
Offline javalin
« Reply #4 on: 06 March 2011, 19:53 »
ok - sounds not disasterous.  Can the UJ just be popped back together?  Do I need to lower the subframe again?
Ta
James
« Reply #5 on: 06 March 2011, 20:55 »
Ta
James
Yes you may need to drop the subframe again :smiley:
Offline javalin
« Reply #6 on: 07 March 2011, 10:00 »
ok thanks.
Anybody done a write up, or any pictures of steering related bits under the bonnet?  Searched and googled but no particular joy.
Ta muchly,
James
« Reply #7 on: 07 March 2011, 10:21 »
i would undo the column and pull it out a bit rather than dropping the subframe.
you have 3 fixing points, bolt thru the uj holding it to the rack, another bolt thru the uj holding it to the bottom of the column, and also the column is in 2 halves so it could have come undone there in the middle somewhere.
start inside the car as its less dirty  :grin:
take out the dasdh undertray and spin the wheel while you watch the uj,. if you need to pull the column out a bit undo the stalk plugs and the bolt holding the ign lock housing to the outer column tubing. its a shear bolt but i bet its loose anyway!
then if the uj is still attached to the column you need to undo and remove the nut & bolt holding it on and the uj will pop out.
you may even have split the column in the middle where it telescopes in the event of an accident, but i dont think that will have happened
Offline javalin
« Reply #8 on: 07 March 2011, 10:28 »
Thanks rubJonny - useful information.  Will check it out tonight/tomorrow.
James
Offline javalin
« Reply #9 on: 07 March 2011, 18:27 »
yup - RubJonny was spot on....
Took the steering column panels off and....
http://javalins.wordpress.com/2011/03/07/mk3-golf-front-bushes-part-2/
James
