Author Topic: done bushes - broken steering...  (Read 4237 times)
Re: done bushes - broken steering...
« Reply #10 on: 08 March 2011, 10:06 »
nice easy fix then :)
Offline javalin
« Reply #11 on: 09 March 2011, 19:37 »
right.  Steering fixed.  And now the dash clock (etc) has reset and the airbag light is on.  Need to scan it for the airbag code.  I wouldn't have thought that Id pulled the column enough to upset the electrical connectors?
dash appears to work now, bar scraping noise from behind steering wheel.
edit -> VCDS shows code as:
00588 - Airbag Igniter; Driver Side (N95)
        32-00 - Resistance too High
VW have it on Friday to do alignment/tracking stuff - so they can sort it then....  Don't like playing with airbags.  I like the warning in RossTech...
When "Short to positive" or "Short to ground" is found, DO NOT CLEAR THE DTC. This can cause the airbag to deploy. See repair manual for more information.
http://wiki.ross-tech.com/wiki/index.php/00588
James
« Last Edit: 09 March 2011, 20:33 by javalin »
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
