Author Topic: Dan's mk2 8v to ABF project **Build For Le Mans??**  (Read 165973 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: Dan's mk2 8v to ABF 'restoration' project
« Reply #180 on: 18 July 2011, 20:34 »
Electric wing mirrors on way.. not sure whether electric included or not will see when arrive can just make up a loom if not..
Also a new mk3 16v ecu without immobiliser which has saved me £55 if it works  :wink:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #181 on: 18 July 2011, 21:16 »
Right just spent a half hour labelling up my loom from Rubjonny he sent me a good PM which should make it so much easier for other people like me who are not that great with electrics  :smiley:
This is on behalf of Rubjonny hope he doesnt mind -
small bit that goes on the engine:
2 & 3 pin plug furthest away from round plug - idle & tps plugs on the throttle body
3 pin plug near round plug - dizzy
2 pin white plug - white coolant sensor side of head
single spade connector - black coolant sensor side of head
ring terminal - bolt to rear of head
3 pin & 5 pin plug - isv and fuel rail
blue wire with single spade - large blue or brown sensor on filter housing (has black outer sheath, peel back the big rubber boot to check wire colour)
yellow wire with single spade - large white sensor on filter housing (has black outer sheath, peel back the big rubber boot to check wire colour)
green/black single spade - small white sensor on filter housing
fusebox:
4 main fb plugs will only fit the sockets they need to go in due to the layout, pin orientation and the locking peg on the back
single pin with large spade and red wire - Z/1
single pin grey/white wire - diagnostics
3 random single wires - mk3 dash so unused
engine bay:
7 pin plug near ecu connector - the old mk2 tci-h unit
2 pin and 4 pin plugs near fusebox plugs - inlet temp and lambda
2 pin plug on its own with red/white and brown/white - outside temp sensor in passenger side inner wing
brown ring terminal on its own - battery -ve
2 pin plug red/black and blue/black - reverse switch
single pin plug blue wire - alternator wire (the blue wire on mk2 lighting loom near battery +ve is now unused, or you can use this instead whichever is easier)
3x 3 pin plugs near big round plug - knock sensors and crank sensor. the 2 knock sensor plugs are the ones that are the same shape, and are colour coded to the knock sensor plugs
chunky red/black wire - starter motor
diagnostics and immob box:
black - ign live
brown - earth (i use the stud on the a pillar with 13mm nut)
red/white and brown - live and earth to ciggy lighter wires
HTH
Offline Len
« Reply #182 on: 22 July 2011, 08:54 »
All hail rubjonny! :wink:
www.sas.org.uk
www.the-ace.org.uk
Offline SoundillusioN
« Reply #183 on: 24 July 2011, 01:12 »
not seen him about much though.
Offline lemski
  • 16v
« Reply #184 on: 24 July 2011, 10:24 »
Did u get my pm mate?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #185 on: 24 July 2011, 10:36 »
Yer sorry am at great Yarmouth at the mo what was it you were saying I didn't totally understand lol
Offline lemski
  • 16v
« Reply #186 on: 24 July 2011, 11:37 »
Am off with a differant gear linkage setup. So my hydro set ups up for grabs. Was offerin u it first b4 I put it in classifieds
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #187 on: 24 July 2011, 12:44 »
Oh right I'm gona stay with cable clutch thanks mate pm me a price though if it's cheap enough I may have it lol  :smiley:
Offline Len
« Reply #188 on: 25 July 2011, 08:46 »
You wont either!
www.sas.org.uk
www.the-ace.org.uk
« Reply #189 on: 25 July 2011, 09:22 »
