Author Topic: Dan's mk2 8v to ABF project **Build For Le Mans??**  (Read 165844 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: Dan's mk2 8v to ABF 'restoration' project
« Reply #170 on: 15 July 2011, 06:41 »
Yer would love them please mate..
Will post pics soon mate
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #171 on: 17 July 2011, 13:33 »
engine bay has a coat of primer.. subframe has been wire brushed and has first coat of hammerite.. then was rained off  :angry: hopefully do some more tomorrow if weather holds up  :smiley:
Offline Neo Badness
  • Feet are for pedals
« Reply #172 on: 17 July 2011, 23:31 »
PM'd you bud :wink:
Offline SoundillusioN
« Reply #173 on: 18 July 2011, 09:50 »
 :cool:  I expect to see pictures soon...
The weather put me in a mood yesterday!
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #174 on: 18 July 2011, 10:18 »
Pics today hopefully if weather holds off.. I had enough of this rain already  :angry:
« Reply #175 on: 18 July 2011, 10:20 »
Yeah it really needs to fook off as I need to pic up my pace again!
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #176 on: 18 July 2011, 10:41 »
Your doing well with the bonnets mate  :smiley: your better at uploading pics than me lol
« Reply #177 on: 18 July 2011, 11:22 »
I often do bits and bobs to the car when I can but don't often post until I have some proof as I get b*tched at.  :grin:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #178 on: 18 July 2011, 16:42 »
Right well progress is being made.. finally.. i have primed the bay and given it a couple of coats of VW diamond black.. the finish is shocking but this is only going to be a temporary measure till i can get it on the road save a bit of money and pay a bodyshop to do it all properly.. I need to get some more black so that i get a good colour even if the finish is sh!t.. the only reason the finish is bad is i havent had time to prep the bay properly and im very impatient with rattle cans  :grin: :grin:
I have also given the subframe 2 coats of black hammerite it also looks bad but its only to serve a purpose as just dont have the time/money to spend getting it blasted and powdercoated for very little gain over than looks and OEM'ness..
Heres some pics its coming along nicely and im trying to find as much time as possible between work and such..
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #179 on: 18 July 2011, 19:29 »
As some of you may know im going to be running a cable clutch as cant be arsed with all the hydraulic stuff.. Here is info from Neo Badness for cable clutch i need to buy all these parts..
- Quote Neo Badness -
SEAT (?) Part no 02B 141 708A bearing bracket £44.62,
Passat syncro part number is 02A 141 708B £33.47.
You will need the actuator (the rubber boot is separate mind) with both bolts,the cable holding bracket from the gearbox to the gearbox mount,then the cable (yes a toledo 16v cable is right)
It will cost "about" £145.00 all in.
The actuator is about £40.00
the bracket about £45.00
The cable about £43.00
plus the rubber boot and the bolts to fit it all
I got all this info from
http://www.clubgti.com/forum/showthread.php?t=107068
HTH's
