Author Topic: MPG  (Read 2988 times)
Offline Rich16v
MPG
« on: 11 March 2005, 16:33 »
my 2L 16v was running well rough and l had to drive at 50-60 on the motorway, while it was like this it said about 35mpg. l've changed the ECU & fuel pump relays and its running better than ever but at the same speed it says 27mpg, does it work out the average of the journey so far or what its doing at that moment. l'm not going to get to worked up over this because its nice to have it running so well, l'll just have to stop looking and just fill it up when its empty.
Rich
Offline Overseer
Re: MPG
« Reply #1 on: 11 March 2005, 17:49 »
have you changed the MFA position?
mrwotto
Re: MPG
« Reply #2 on: 11 March 2005, 19:04 »
It may be on position 2 which is the average mpg since you last reset it, not like position 1 which is a trip computer
Offline Rich16v
Re: MPG
« Reply #3 on: 11 March 2005, 19:54 »
MFA position,? :huh: l didn't know you could change it or reset it? :embarassed:
so thats what the 1 & 2 are for on the switch, l thought that was something to do with the intermittent wiper.
« Last Edit: 11 March 2005, 23:12 by Rich16v »
mrwotto
Re: MPG
« Reply #4 on: 12 March 2005, 20:16 »
No as stated before position 1 is kind of a trip computer, position  2 keeps its memory till you reset it
Offline R1-Jay
  • Mk3 16v & ex BSB R1 (180bhp!!!)
Re: MPG
« Reply #5 on: 12 March 2005, 20:33 »
at 50-60 you should be getting much more than that!!!
i get about 40 if i do sit at that speed, i get on average 35 if it sit on a constant 80mph
Offline davero
Re: MPG
« Reply #6 on: 12 March 2005, 23:50 »
at 50-60 i would get 44 over a hundred mile journey. 27mpg sounds about right for setting 2 if you do mostly town miles
Offline adyh
Re: MPG
« Reply #7 on: 14 March 2005, 09:25 »
To reset the MFA stats , select the position you want to reset  , and then move the switch to the nearest 0 on the stalk [left if pos 1 right if pos2 ] its spring loaded and you will have to hold it there for a couple of seconds .
mrwotto
Re: MPG
« Reply #8 on: 14 March 2005, 10:28 »
I am not convinced that the mpg reading is actually correct, never tested it, maybe will do when i go to newark
redcarboy
Re: MPG
« Reply #9 on: 14 March 2005, 13:12 »
Top mpg im getting at the mo is 30.7 on a 40 mile round trip 14-20 round town and its just been serviced maybe ill check mine on the way down to newark too.. :rolleyes: :smiley:
Throttle body is coming off as well for a clean probably aint been done since the car was new... :shocked:
« Last Edit: 14 March 2005, 13:16 by Count-Von-Carstein »
