Author Topic: New exhaust + gearbox change  (Read 999 times)
Offline cobalt6700
« on: 05 March 2011, 13:07 »
In about a week im going to take the golf apart and take me the gearbox off - its a bit tired and is getting a replacement. When doing this its getting new clutch/cable/engine mounts etc. i am also planning on putting a new exhaust on it as the baffles have gone on mine. will also be replaing the PS rack as it has alot of play.
So i have a couple of questions
is GSF the best place to get a new exhaust from? Should i go for a 16V exhaust as its larger bore?
and does anyone have any tips for changing a gearbox? was planning on taking the engine out with the box and putting it on my stand, then i can get to the rack easy, and the gearbox change is easy too.
also any other tips/hints would be nice, first time playing with golf engines  :grin:
1993 GTI 8v 5dr matt black and green - the 'sh!tball rally car'
1997 GTI 8v 3dr metalic black - the daily driver
2002 3DR 1.8T AUM silver - the new daily
1993 Jeep cherokee 4L - the weapon :D
Re: New exhaust + gearbox change
« Reply #1 on: 05 March 2011, 19:55 »
To replace the steering rack the subframe needs lowering anyway.  :smiley:
Offline javalin
« Reply #2 on: 06 March 2011, 09:21 »
might be worth looking at a set of poly-bushes for it, as you're taking it all appart anyway.  Got mine from http://cgi.ebay.co.uk/VW-Golf-MK3-8v-Front-Bushes-Polyurethane-/280631103942?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4156ead1c6 - just fitting them at the moment..... :-)
Includes stearing rack bushes and subframe ones, so easy whilst its all apart.
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline cobalt6700
« Reply #3 on: 10 March 2011, 10:14 »
Cheers for that, bit out of my budget at the mo.
Does anyone know if the mk3 8v AGG has a spigot bearing in the flywheel?
« Reply #4 on: 10 March 2011, 14:53 »
nope :)
edit: unless its auto?
Offline cobalt6700
« Reply #5 on: 10 March 2011, 21:27 »
Nice one, makes things a bit easier  :smiley:
Nah, not an auto  :smiley:
