Author Topic: rear caliper carrier bolts  (Read 1882 times)
Offline jmorris
« on: 02 March 2011, 21:16 »
hey guys, im in the middle of changing my rear discs and im having trouble getting the 2 8mm allen head bolts out that hold the caliper carrier in place, i have done a search and seen that many people use the irwin  bolt removers i was just wondering if anyone new what size i would need so i can get the right set.
cheers
jake
Offline AudiA8Quattro
Re: rear caliper carrier bolts
« Reply #1 on: 02 March 2011, 21:38 »
Not sure. I think one from either set should work.
I would just buy both sets.
Offline gm8
« Reply #2 on: 02 March 2011, 21:56 »
i had this prob on my mk2 ibiza , i used a chisel and lump hammer to free the bolt , and replaced with hex bolts
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 02 March 2011, 23:32 »
Offline danmusic24
« Reply #4 on: 03 March 2011, 09:59 »
as above! i used hammer and chisel to remove lower one and had drill the top one out...horrible job,got replacements form vw £1.50 each
Offline tweed
« Reply #5 on: 03 March 2011, 19:30 »
I use wd40, a allen key and a bar to fit over the allen key for leverage. I don't find that hard of a job to be honest  :lipsrsealed:
Offline jmorris
« Reply #6 on: 03 March 2011, 23:33 »
thanks for the help, i used the irwin method  :wink: worked a treat. done the one side then ran out of time, ill tackle the other tomorrow!
jake
« Reply #7 on: 03 March 2011, 23:53 »
jake
They are worth their weight in gold.
I never understand why people chisel or drill the heads, when there is such an easy alternative  :grin:
Offline gm8
« Reply #8 on: 04 March 2011, 00:37 »
jake
when you only have one car with a wheel off and the nearest place to buy such things is miles away , you tend to try all sorts of crazy things  :evil:
Offline bored_Welsh_lad
« Reply #9 on: 04 March 2011, 05:50 »
jake
Prior planning sweetheart...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
