Author Topic: funny problem vr6 spluttering  (Read 812 times)
Offline forsh
« on: 27 February 2011, 09:21 »
had a funny problem the other day with my vr6
driving home from work i felt the car had lot a bit of power and spluttering ,i was going about 70-80kmh
i got home and check under the bonnet and found the expansion tank was lower then min
ive had a small water leak now and then but when i looked the other day it was a bit more then usuall
there was liquid near the gear changer and a bit was dripping down from the expansion tank
can the engine move about so much that the coolant in the expansion tank moves around a lot so it leaks from the cap?
ive ordered a new cap (blue one) cos when i open the tank there is a hiss and escape of air
what other things should i check
Offline forsh
Re: funny problem vr6 spluttering
« Reply #1 on: 27 February 2011, 13:15 »
found out why it was coughing and spluttering
1 spark plug leads was arching
now i need to buy a new one
Offline harlemex
« Reply #2 on: 27 February 2011, 13:20 »
check your oil. You wouldnt lose lots of coolant by way of spillage through the cap.
Offline forsh
« Reply #3 on: 27 February 2011, 15:42 »
last year i drained the coolant out and found them clips were a bit nasty ,so i put on normal jubilee clips on the 2 main pipes from the the rad
i am thinking cos the cap is gash that there is a lot of pressure in the system and its leaking from the rad pipes
and the fact the last few weeks its been minus 25
but ill look at the oil tomorrow :)
