Author Topic: mk 3 golf gti 8v rev counter problem...HELP...HELP..HELP PLEASE  (Read 2284 times)
Offline Golfgtimadman
Hi every1,i have a problem with me rev counter..it all works fine wen running,the problem is wen braking to slow down..the rev counter goes all crazy and looks like the engine cuts out but it doesnt cut out,i recently changed the bulbs in the cluster..could this have anything to do with the problem.when i got the car it needed new front disks,the previous owner kept driving it wiv the disks all worn down,could this have damaged anything like wires...i dnot no and this is doin my head in so any help would be much appreciated...thanks and hope to hear from sum1 that knows how to fix this problem
Offline robz
Re: mk 3 golf gti 8v rev counter problem...HELP...HELP..HELP PLEASE
« Reply #1 on: 25 February 2011, 13:45 »
ok, difficult to read..
i very much doubt it has anything to do with the rev counter, that is only showing you what is happening, use the search as i think you'll find it is a common mk3 ailment!
also telling us what engine/model/year would help ;)
« Reply #2 on: 25 February 2011, 14:01 »
i have used the search n no results found.the car is a 1996 mk3 golf gti 8v
« Reply #3 on: 25 February 2011, 14:07 »
Is the gauge playing up or do the revs actually go up and down.  :smiley:
Offline robz
« Reply #4 on: 25 February 2011, 14:07 »
as above...
is the engine actually trying to cut out???
« Reply #5 on: 25 February 2011, 14:09 »
just the guage,theres no problems with the revs at all.and its only wen i brake uva wise all is gud
« Reply #6 on: 25 February 2011, 14:10 »
Check and clean all the earths as a 1st step.
« Reply #7 on: 25 February 2011, 14:12 »
any help to where all the earths r..im quite new to the vw's
Offline harlemex
« Reply #8 on: 25 February 2011, 14:17 »
+1 where are they?
Offline Seanl
« Reply #9 on: 25 February 2011, 17:37 »
Seeing as you have just changed the dial leds, check you plugged the dials back in properly. It may be that there is just a loose connection on the plug and under heavy breaking, the contact is being lost a little on that particular pin. As its only happened since you replaced your leds, that may be a good place to start before freeking out!!
