Author Topic: Keeps cutting out!!!!  (Read 1744 times)
Offline Jakethesnake
« on: 24 February 2011, 18:45 »
Hey everyone,
          About 4 weeks ago i became the owner of a lovely GTI 1.8t. Basically when i first got the car it was fine, but about a day later it cut out randomly?! it started fine after so didnt really think to much of it. but then kept doin it for days and days after. the only problem was it was getting worse, when it cut out, it wouldnt start again for about 3 or 4 mins... I finally took it to a garage and he said it would probly be the Airflow sensor?.. so replaced that and thought to myself sorted.. but no, its even worse, as i was driving home it didnt seem right at all, when i put my foot down it was pulling back like i was about to run out of fuel. i only just managed to get it on my drive, and then it cut out. Really sounded like it was starving of fuel. Now when i try to start it, it starts then cuts out like straight away... Sorry for the life story but i needed to explain some how :P. A friend thinks my fuel pump has had it?
Anyone have any ideas on what actually goin on?
Help would really be amazing.
Thanks
Offline ade_aidy_ady
Re: Keeps cutting out!!!!
« Reply #1 on: 24 February 2011, 19:29 »
Exact same issues here.... only seems to be running rich as fault code confirms..."bank 1 rich".....
Offline houston
« Reply #2 on: 24 February 2011, 19:31 »
running rich would prob be lambda sensor or maf.
have you had the car scanned for codes? starting and cutting straight out would have me guess immobilizer, but could be many things
« Reply #3 on: 24 February 2011, 20:56 »
Not my maf as I've tested and is ok.....lambda I'm not sure about....would a dodgy one cause it to kangaroo after start up from cold...?
Offline houston
« Reply #4 on: 24 February 2011, 21:01 »
not really, if its kangarooing then its most likely fueling issue. get it scanned, itll have logged a fault
« Reply #5 on: 24 February 2011, 21:04 »
I did...scan showed "bank 1 running rich" and "pressure drop between turbo and throttle body"
On idle car def feels that's it over fueling wanting to stall......
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 24 February 2011, 21:04 »
Faulty crank sensor is the most common cause for cutting out/failing to restart. Need the fault codes read first to point you in the right direction.
ade you should probably start a separate thread i think your issue is something different. (in other words, stop hijacking! :grin: )
Offline loopyloo28
« Reply #7 on: 12 March 2011, 22:05 »
hey im having the same problem guys   only thing is i have not had a fault code or managment light on the dash   would there still be a code as i dont wanna pay for some thing thats not there !
Offline ashie_b1986
  • mk4 golf gti 1.8 turbo AUM 2001
« Reply #8 on: 12 March 2011, 22:09 »
even tho you dont have a warning light showing on your dash you should still have a code ,
i had a problem with my car and no lights were showing but when it was put on a reader  it showed the codes,
so get it checked mate  :smiley:
Offline richw911
« Reply #9 on: 12 March 2011, 22:09 »
Yes code will be stored in the ECU  :wink:
Get one of these :
http://cgi.ebay.co.uk/VW-AUDI-Diagnostic-Fault-Code-Reader-VAG-OBD2-OBD-U280-/160555790154?pt=UK_Diagnostic_Tools_Equipment&hash=item2561deef4a
