Author Topic: 16v k-jet vs 16v ABF  (Read 5660 times)
Offline laurenceyon
« on: 22 February 2011, 00:10 »
Hi gents
I'm seriously thinking of doing the conversion, I love the originality of my valver however the reliability stinks!
In your humble and educated opinion's, what are the pros and cons of the conversion?
Will I lose the fun factor in the high rev range that I so love?
« Last Edit: 22 February 2011, 00:12 by laurenceyon »
Hi my name is Laurence, I'm very much like you. Only better.
Offline Sam
  • Sam I am
Re: 16v k-jet vs 16v ABF
« Reply #1 on: 22 February 2011, 00:18 »
You are about to get a 1000 word essay from a man who on here is as faceless as the stig. Cue DH.....
« Reply #2 on: 22 February 2011, 09:44 »
k-jet = easy to wire in, thats just about it really
digi = easy to setup as no co or ignition tuning required, all ecu controlled
digi has proper knock control so its better able to keep the abf healthy, k-jet you need to keep on top of it to stop the think knocking itself to death. to tune k-jet properly you need access to k-jet fuel pressure test gauges.
I've run mine on both, and digi wins for me
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 22 February 2011, 13:57 »
CBA.  Use the search, you idle c*nts.
Offline Sam
  • Sam I am
« Reply #4 on: 22 February 2011, 14:23 »
OMFG, thats a first for you thomas  :grin:
 Oh and jonny, you ruined it  :angry:
Offline danny_p
« Reply #5 on: 22 February 2011, 15:24 »
I have also run out of botherd on this subject
all the VW's have gone bar 1.
Offline emery1990
« Reply #6 on: 22 February 2011, 15:45 »
You will gain fun factor not loose it! Plenty more torque, dont fuel it with k-jet, its old and fiddly.
« Reply #7 on: 22 February 2011, 15:51 »
If your going to fit a ABF run it on proper / factory management instead of k jet
Offline mk2bal
« Reply #8 on: 22 February 2011, 16:44 »
If your kjet setup is working fine, and you want the conversion done in a day, leave it on kjet. If you want a bit better fuel economy, go for digi.however, a digi loom is then needed and all digi ancillaries, the loom then needs splicing in to yours before plugging into the engine, and really you've got to take your dash out to do this..I had to remove dash to do my kjet, as it was a carb before. I used a complete kr car for everything I needed. Had I known what I know now I'd have prob done it digi, as I don't plan to sell the car etc etc, so the extra work would have been worth it to me..
« Reply #9 on: 22 February 2011, 20:45 »
I believe later cars are plug and play so easier.
