Author Topic: Deactivating Xenon DRL's  (Read 3626 times)
Offline JamesR27
« on: 17 February 2011, 20:41 »
Hi,
I was just wondering if the DRL's for xenons can be turned off. I was trying what the manual said on the weekend but I could not seem to get them switched off.
Instructions were pull down back the indicator stalk. Then turn the power on and off for 3 secs.
Is this correct ?
Mk 8.5 Clubsport Pure White, Queenstown, DCC.
MK 7.5 R Pure White, Pretoria Silver, DCC, Rear Camera.
Gone - MK 7 GTI Carbon Grey, Rear Camera, Service Pack.
Gone - MK 6 GTI  Reflex Silver, Monza Shadows, RCD 510, Rear Camera, Bluetooth, Tyre Pressure Sensor, Xenons Convenience pack, Service Pack :)
Gone - MK 5 GTI Reflex Silver, Monza II 18's, Luxury Pack, Mulitchanger
Offline Snoopy
  • Moderator
  • Geoff.
Re: Deactivating Xenon DRL's
« Reply #1 on: 17 February 2011, 20:52 »
Does not work with Xenons.
You have to use VCDS and goto the following.
Central electric ---> Coding --->  long code helper
Byte 11 select it
A box below will now appear.
A tick box next to 'Daytime running lights via low beam' will be ticked, click it to untick it. click back, click 'do it'.
DRL as xenons will now be turned off.
« Last Edit: 09 September 2011, 10:07 by Snoopy »
Garage:
35+ years of GTI ownership.
Offline Tone2have
  • Gutted - stolen April 10 but now black is back!
« Reply #2 on: 06 September 2011, 22:49 »
Do you need VCDS to deactivate the other DRL's when you have Xenons fitted as standard?? I not only have permenant headlights but also yellow side lights, rear & number plate lights, and I just don't seem to be able to turn any of them off!! It's like driving a F,in Christmas tree :))
GTI MK6 black, man, 5 dr, 18" Monza shadow, Xenons, RCD510 Dyna Audio, Winter pack, ordered Sept 2009 - Delivered April 2010, stolen next day - gutted
Offline evo1986
« Reply #3 on: 07 September 2011, 08:16 »
Have a look in your mfd convenience settings........
Sales Manager
WhatsApp: 07389107119
Offline Mr_F
« Reply #4 on: 07 September 2011, 10:20 »
+1 I found this feature last night.
61 Plate GTD 5dr, Shadow Blue, 18" Charleston's, Flat Tyre Indicator, Cruise Control, Bi-xenon (With Dynamic Curve), Storage Pack, Winter Pack and RCD 510.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 07 September 2011, 12:00 »
Only if you have the newer Xenons with the LED DRL built in.
Garage:
Offline Mr_F
« Reply #6 on: 07 September 2011, 12:50 »
I'm thinking of leaving mine turned off to experiment, have had more near collisions in the past week than I have had in a whole year, each one I was driving normally and in no way in the wrong.  I think they may be dazzlingly hypnotic!
Offline Tone2have
« Reply #7 on: 08 September 2011, 21:17 »
Just checked my MFD & I haven't got that option so I'm still lit up like a christmas tree :)
Offline Mr_F
« Reply #8 on: 09 September 2011, 10:01 »
Maybe a dealer update required?.....
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #9 on: 09 September 2011, 10:02 »
Tone2have
If your car is a 2010 as listed in your sig it is about the same age as mine. Mine was delivered late March 2010.
If it is a 2010 with the older Xenon lights like mine rather than a 2011 with the LED DRL Xenons. It will probably have them set as mine did.
Front headlights + front side lights + rear lights + number plate lights.
To turn the DRL off on that age of car you have to deactivate them by using VCDS(Vagcom) or similar. (see my second post of this thread)
« Last Edit: 09 September 2011, 10:14 by Snoopy »
Garage:
