Author Topic: Camshaft regrinding  (Read 1972 times)
Offline Khare
  • The bear that khares
Camshaft regrinding
« on: 16 February 2011, 17:39 »
Just read on another thread that the ABF responds well to the inlet cam being regrinded. Called a local machinist shop and they said that I'd need to know the spec I'd want it grinded. What does the ABF respond well to inlet cam-wise? They also said the cost would be "a couple of hundred"....For a little more I'd buy aftermarket cams so I'm not sure on that price. I'm going to call a different shop tomorrow and see what their price is, if not then I'll ask around for recommended specialists  :smiley:
Offline javalin
Re: Camshaft regrinding
« Reply #1 on: 16 February 2011, 19:36 »
surely if you grind an existing cam all you can do is reduce the lift / duration?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Khare
« Reply #2 on: 16 February 2011, 19:39 »
Nope. I don't know exactly how it's done, but the original cams can be ground to a new specification.
« Reply #3 on: 16 February 2011, 19:52 »
Pm sent with some info  :lipsrsealed:
Offline Ess_Three
« Reply #4 on: 16 February 2011, 20:18 »
You grind the base centre diameter down, to leave the lobe sitting higher...of course, you can only go so far before the BCD gets too small for the follower to adjust to...and you are limited to the profile of the lobe depending on what's there to begin with.
For an ABF running Digi 3.2 and a Cat/lambda, you really want lots of lift, and semi-limited duration.
Pointless throwing in 300 degree cams with 10.5mm lift...far better with 268 cams and 11.7mm lift (for example)
Potentially a re-grind will give more lift, and standard-ish duration...which should work. If the lifters will cope.
..but gaining motorcycles.
Offline Len
« Reply #5 on: 17 February 2011, 09:56 »
Not satisfied with 155bhp then!  :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
« Reply #6 on: 17 February 2011, 11:04 »
Power is never enough  :tongue:
Offline Len
« Reply #7 on: 17 February 2011, 13:16 »
You know what can happen playing with cams! Just look at Adam! :rolleyes:
 :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
« Reply #8 on: 17 February 2011, 13:19 »
 :grin:
That's because TSR handled his engine  :grin:
My 8v surprised many at the RR with the kent cam  :wink:
Offline Paul86S2
« Reply #9 on: 17 February 2011, 21:48 »
Danny was selling a set of reground abf cams recently.
Paul
