Author Topic: Door hinge replacement.  (Read 1976 times)
Offline LowlifeDubber
« on: 16 February 2011, 15:57 »
Im going to be changing the doors on the Golf ready for its respray soon.As the hinges/pins have dropped on my current ones im going to get some new hinges.
However my hinges dont seem to look like normal mk3 affairs.In Etka for my year of car,they seem to have some grub screws on the centre of the hinge,mine dont.
Will all others just bolt on?Or did the hinges have a different pcd the later the car got?
Im guessing they will be a pain to change as they have torx bits that are bound to be seized solid. :angry:
Heres what mine look like now(crappy pic)
This is what ETKA says.
Also is there anyway of adjusting my type of hinge to stop the sag while i get my doors on.
Offline tshirt2k
  • Been there...Done that...
Re: Door hinge replacement.
« Reply #1 on: 16 February 2011, 16:25 »
You can adjust them up using a wheel bolt between the bottom hinge and gently closing the door. It bends the hinge slightly to get you at the right position.
Mk3 ABF 16VT Megasquirt V3
« Reply #2 on: 16 February 2011, 16:29 »
The pins are very worn on mine so it will more than likely bugger it completely. :grin:
Offline tshirt2k
« Reply #3 on: 16 February 2011, 16:32 »
Can always try it if they are being replaced anyway. Nothing to loose.
« Reply #4 on: 16 February 2011, 16:34 »
I believe you replace just the pins.
Offline Bellend
« Reply #5 on: 16 February 2011, 17:23 »
Tap them out upwards and replace IIRC.
Where all my moneys went.
« Reply #6 on: 16 February 2011, 17:30 »
I will see if i can get some from vw then.Just a pain that they are different to others tbh :angry:
« Reply #7 on: 16 February 2011, 21:15 »
From memory they look the same as my 1996.
« Reply #8 on: 16 February 2011, 21:30 »
Ah ok,so its not some random hinge some muppet has grafted on,off a 1982 Trabant then :grin:
« Reply #9 on: 16 February 2011, 21:31 »
Would not think so, is it the same on both sides.
