Author Topic: VCDS cable and software  (Read 9742 times)
Offline Buck
  • Das Auto
« on: 15 February 2011, 19:46 »
Hi all
I've been wondering whether it's worth investing in my own cable/software ?
I've seen this for a lot less than the Ross Tech ones at "only" £80
http://www.vag-diagnostics.com/info.html
I've done a search on this forum but not found much info (realise my powers of search may be pants!)
Thoughts?
Offline The Doc
  • E63s Estate - Vito Sport
Re: VCDS cable and software
« Reply #1 on: 15 February 2011, 20:29 »
That's a non genuine version and that's expensive for a non genuine VCDS, you will not be able to update it past the version 10.6 software that it comes with.
Offline Buck
  • Das Auto
« Reply #2 on: 15 February 2011, 20:30 »
Thanks Doc
So, only the original will do?
Offline The Doc
« Reply #3 on: 15 February 2011, 20:40 »
It's your choice, you pay your money, you take your chances.
It should work but it sounds expensive for a blag to me.
I'll have a scout around for a cheaper alternative  :wink:
« Last Edit: 15 February 2011, 20:53 by The Doc »
Offline Buck
  • Das Auto
« Reply #4 on: 15 February 2011, 20:42 »
Thanks again.
Offline ajmoir36
« Reply #5 on: 15 February 2011, 21:11 »
Right here is my 2pence worth.  On that website there is no email addresses, no adresses, no nothing on how to make any contact = suspect to start with.
Next step http://whois.domaintools.com/vag-diagnostics.com
This tells me its registered in stockholm ok, fair enough
Next http://www.google.co.uk/search?hl=en&q=Gottfrid+Swartholm&meta=
Interesting that the name is similar to this person but on just different. notice the V and W in the surname.  Funny that it comes from Sweden aswell?
Suspect.
I hope Ross-Tech have this patented as surely this is just ripping them off as it claims to fully work?
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Buck
  • Das Auto
« Reply #6 on: 15 February 2011, 21:15 »
Hmmm
You're a detective and a half!
So the old adage tha tif its too good ot be true then it usually is?!
Back to my original query - is Ross Tech the only place to get these cables? (Either direct or using the link that Doc posted earlier?)
Suspect.
Offline mike.
« Reply #7 on: 15 February 2011, 21:53 »
You can get original cables HERE
I had a cheap eBay one once but it kept losing comms so bought the original.
I don't mind paying, considering the effort that has been put into the development and the amount of use it has had.
« Last Edit: 15 February 2011, 22:04 by mike. »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Keithuk
« Reply #8 on: 15 February 2011, 21:56 »
For genuine Ross-Tech leads they have distributors I bought mine from Ilexa because I try to support the UK. You can get them a bit cheaper direct of Ross-Tech if you get a good exchange rate.
There are very cheap none genuine leads on eBay but you have to use VCDS-Lite which doesn't have all options available, Function Chart / Feature Comparison. It all depends how much checking and adjusting you want to do or how much you can afford.
There are things that people are trying but I don't want to post them on here. :wink:
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline The Doc
« Reply #9 on: 15 February 2011, 22:04 »
Tops and bottoms, most buy blag versions then move onto the genuine one, save yourself a few quid and buy a genuine VCDS once  :wink:
OR
Rent this one: http://www.golfgtiforum.co.uk/index.php?topic=180337.0
