Author Topic: engine mounts  (Read 3700 times)
Offline shepgti
engine mounts
« on: 15 February 2011, 13:35 »
does the abf require moving of the engine mount brackets?
Re: engine mounts
« Reply #1 on: 15 February 2011, 14:02 »
only if its a 1.0-1.3 shell, same as putting any big block into 1.0-1.3
Offline shepgti
Re: engine mounts
« Reply #2 on: 15 February 2011, 14:09 »
mines a 1.5 so guess they have the same mounts then
Offline SoundillusioN
Re: engine mounts
« Reply #3 on: 15 February 2011, 14:46 »
Yep sadly  :grin: ...... but this is news to me... when did an ABF plan kick in!?
« Last Edit: 15 February 2011, 15:32 by SoundillusioN »
Re: engine mounts
« Reply #4 on: 15 February 2011, 14:54 »
1.5 has big block mountings so abf will drop right in, unbolt 1.5 engine brackets and bolt to the abf. just need to trim timing belt covers a bit, are you goinf to use the 1.5 or other mk1/2 gearbox?
Offline shepgti
Re: engine mounts
« Reply #5 on: 15 February 2011, 19:25 »
No real plans yet, just looking at it as a slightly easier conversion if I decide to change the engine.
Re: engine mounts
« Reply #6 on: 15 February 2011, 19:58 »
Are planning on running it on carbs or injection.
Re: engine mounts
« Reply #7 on: 15 February 2011, 20:25 »
Because the answer to this then moves the transplant on to all the stuff that's required for fueling.
Re: engine mounts
« Reply #8 on: 15 February 2011, 20:43 »
Yes in a way, bike or webber carbs would be ace however but will be juicy.
Offline shepgti
Re: engine mounts
« Reply #9 on: 16 February 2011, 00:09 »
as i say this isnt a definate plan although if i do decide to change the engine it will be to a 2.0 16v, would like to run it on itb's if i did. remeber this car is only a weekend toy so things like mpg/practicality just dont matter :smiley:
