Author Topic: oil pressure light  (Read 3212 times)
Offline hockeylad72
oil pressure light
« on: 05 March 2005, 00:45 »
more help required
oil pressure warning light appear on for a few seconds while driving usually between 200 and 3000 revs also sometimes happens when going round corners, car has recently been serviced with semi synthetic oil, oil lever as it should be. any help would be appreciated
oh its a 1.8 8v gti PB engine code 1988 model
cheers
Offline Dannyd
  • LOOK AT THAT VALVER GO!
Re: oil pressure light
« Reply #1 on: 05 March 2005, 06:34 »
sender is on the blink!
 :sad:
wacked up on scuby snacks!
Offline mk2gtigolf16v
« Reply #2 on: 07 March 2005, 10:19 »
Hiya, i had the same problem on my 16v after and engine swap,
i just got the oil pressure switches from the donor car and used them, it now never buzzes at me anymore.
On an 8v there is one above the oil filter and another one on the right hand side of the engine, as u stand infront of the car.  :smiley:
Offline hockeylad72
« Reply #3 on: 07 March 2005, 10:58 »
its good to know its only the pressure switch, a nice cheap repair :laugh:
cheers for the advice
Offline ...joe
« Reply #4 on: 07 March 2005, 16:16 »
if it happens when going round corners its normally an indication that the oil is too low so as it sloshes to one side of the sump the pump can't pick it up. but you say the oil level is fine?? errm don't know!!!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Judderi
« Reply #5 on: 07 March 2005, 16:57 »
Gotta say i agree with gtijoe. Double check your oil level and make sure its topped up to the max.
Offline hockeylad72
« Reply #6 on: 07 March 2005, 21:06 »
oil level spot on max
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #7 on: 07 March 2005, 21:44 »
Make sure the yellow plastic piece on the dip stick is all there, they do break and it could be making the dip stick go down that bit further than it should, giving you an incorrect oil level! only a couple of quid to replace :)
Offline hockeylad72
« Reply #8 on: 07 March 2005, 22:06 »
mines is red and it has already been replaced
Veedubgt18v
« Reply #9 on: 07 March 2005, 22:33 »
pick up pipe for the oil pump could be gumbed up with crap can cause insuffucent pressure.
