Author Topic: HELP wont start after engine rebuild!!!  (Read 2522 times)
Offline elnigel
« on: 04 March 2005, 17:00 »
Hi ive just spent 2 years reboring my engine and restoring it, put everything back together and it wont fire.
AAAAAAAAAAHHHHHHHHHHHHHHHHH
Ive got fuel and it turns over ok, when i check the spark against the block it seems to spark as you turn the key but then no further sparks
Any ideas, im soooooooo annoyed
its an 89 digifant 8v golf by the way
Thanks everyone :smiley: :sad: :smiley:
1989 Golf GTI 8v (work in progress!)
1998 Seat Ibiza tdi
Re: HELP wont start after engine rebuild!!!
« Reply #1 on: 04 March 2005, 17:43 »
Knackered ignition switch perhaps?  Set it to the ignition position then jump the starter motor, or bump start it :)
Offline elnigel
« Reply #2 on: 05 March 2005, 18:43 »
it turns over, it just wont spark. any ideas :lipsrsealed:
pppppllllllllllllllllleeeeeeeeeeeaaaaaaaaaaaaassssssssssssseeeeeeeeeeeeee!!!!!!!!!!!!!!!!!!
1998 Seat Ibiza tdi
free
« Reply #3 on: 05 March 2005, 18:53 »
u sure timings rite
« Reply #4 on: 05 March 2005, 18:53 »
Fit a new rotor arm & dizzy cap, then check the ht leads then the coil.
Offline elnigel
« Reply #5 on: 05 March 2005, 19:48 »
rotor, dizzy n leads ok, it gives one spark as you turn the key but then nothing,
how do you check the coil?
i thought if the coil was knackered it wouldnt spark at all
thanks for your help
 :wink:
1998 Seat Ibiza tdi
« Reply #6 on: 05 March 2005, 19:58 »
Dunno :)  From the Haynes:
Coil - testing 2
1 The coil is located on the bulkhead under
the plenum chamber (see illustration). It
should be periodically wiped clean to prevent
HT voltage loss through possible arcing.
2 To ensure that the correct HT polarity at the
spark plugs, the coil LT leads must always be
connected correctly. The ignition lead from
the fusebox must be connected to the
positive (+) terminal 15, and the distributor
lead (usually green) must be connected to the
negative (-) terminal 1. Incorrect connections
can cause bad starting, misfiring, and short
spark plug life.
3 Complete testing of the coil requires special
equipment. However, if an ohmmeter is
available, the primary and secondary winding
resistances can be checked and compared
with those specified. During testing, the LT
and HT wires must be disconnected from the
coil.
4 To test the primary winding, connect the
ohmmeter between the two LT terminals. To
test the secondary winding, connect the
ohmmeter between the negative (-) terminal 1
and the HT terminal.
Offline elnigel
« Reply #7 on: 05 March 2005, 20:34 »
will try testing it in the morning, thanks mate
Fingers crossed!!!
1998 Seat Ibiza tdi
« Reply #8 on: 05 March 2005, 20:56 »
Oh and you'll need the coil specs:
Pre August 1987:
Primary winding resistance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.52 to 0.76 ohm
Secondary winding resistance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2400 to 3500 ohm
From August 1987:
Primary winding resistance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.6 to 0.8 ohm
Secondary winding resistance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6900 to 8500 ohm
« Last Edit: 08 March 2005, 09:51 by rubjonny »
Offline mk1
« Reply #9 on: 06 March 2005, 18:37 »
Check for spark when cranking, if there is no spark unplug distributer and check for voltage on outer 2 wires and if ok rest h.t lead near earth, get a piece of wire and earth one end and touch centre pin on the distributer plug, you should get a good spark when you touch it on and off. If you do, replace the hall sensor in the distributer, if not suspect module or coil etc. Hope this helps.
Steve.
