Author Topic: Obd problem  (Read 2393 times)
Offline neil1780
Obd problem
« on: 13 February 2011, 16:11 »
It appears my car is obd1 is this correct it's a 97? Also I tried a launch machine today to read any faults and that won't read the ecu either any ideas why?
V6 4MOTION
Offline boneybradley
  • Back in a Mk3...
Re: Obd problem
« Reply #1 on: 13 February 2011, 17:02 »
should be obd2 on a 97 (obd1 uses a 2x2 connection)
Offline neil1780
Re: Obd problem
« Reply #2 on: 13 February 2011, 17:11 »
Ok I got you it's just 1 plug. Why won't it read then? The plug on the car only has 4 pins inside it is that right?
V6 4MOTION
Re: Obd problem
« Reply #3 on: 14 February 2011, 10:57 »
obd1/2 doesnt really make a difference the diagnostics system is the same, just the shape of the plug. and ya, it only has 4 pins. does the led on the diagnostics plug light up? check the fuse for it, on same one as ciggy lighter. ignition needs to be on as well
Offline neil1780
Re: Obd problem
« Reply #4 on: 14 February 2011, 15:31 »
Yes mate it lights up checked all fuses in car an all fine.
V6 4MOTION
Re: Obd problem
« Reply #5 on: 14 February 2011, 16:16 »
can you read any other modules such as immobiliser, airbag, abs etc?
Offline neil1780
Re: Obd problem
« Reply #6 on: 14 February 2011, 18:12 »
No nothing at all mate.
V6 4MOTION
Offline danmusic24
Re: Obd problem
« Reply #7 on: 14 February 2011, 18:39 »
ecu is f**ked mate! got a feeling thats why you car aint starting....i done same as you,got lead from ebay plugged it in and nothing....bad ecu.
Offline neil1780
Re: Obd problem
« Reply #8 on: 14 February 2011, 19:19 »
Got another ecu here an plugged that one in and can't read it either an car still won't go, it's not programmed to the car but should still start then immob will cut it.
V6 4MOTION
Offline danmusic24
Re: Obd problem
« Reply #9 on: 14 February 2011, 19:30 »
what vagcom you using? vcds lite?
