Author Topic: Obd problem  (Read 2392 times)
Offline neil1780
Re: Obd problem
« Reply #10 on: 14 February 2011, 20:02 »
Not sure it was a launch machine from a local garage an tried a reader from another garage both didn't work.
V6 4MOTION
Offline danmusic24
Re: Obd problem
« Reply #11 on: 14 February 2011, 21:00 »
have you had a go at setting up vagcom on a laptop with the cable your just brought? :smiley:
Offline neil1780
Re: Obd problem
« Reply #12 on: 14 February 2011, 21:16 »
will do but but its not here yet :sad:
V6 4MOTION
Offline danmusic24
Re: Obd problem
« Reply #13 on: 15 February 2011, 07:00 »
Cool  :grin:
Offline neil1780
Re: Obd problem
« Reply #14 on: 15 February 2011, 19:10 »
got cable today can get it to work! interface not found have changed port number and driver is installed for the cable. also downloaded vcds from rosstech rather than the disc but still the same. why is nothing ever easy!!!!!!!
oh im on windows 7 can anyone shed some light.
V6 4MOTION
Re: Obd problem
« Reply #15 on: 16 February 2011, 10:10 »
need to go into device managed and check what number the virtual com port is, if its higher than 4 you need to change it to 4. you may have to reassign another ports number to free up a space for it.
also you must do the test with the cable plugged into the car with the ignition on
Offline danmusic24
Re: Obd problem
« Reply #16 on: 16 February 2011, 15:41 »
disc and driver that came with my cable was sh!te! i use windows 7 and just plugged cable in and windows found a driver and said it was ready for use,then booted up vcds lite,ran com test,saved,and plugged into car but only works on SELECT CONTROL MODULE... for some reason...
did you download third party version of vcds?
Offline neil1780
Re: Obd problem
« Reply #17 on: 17 February 2011, 09:55 »
Downloaded vcds from rosstech an driver for cable installed fine changed com port but still won't work bud.
V6 4MOTION
Re: Obd problem
« Reply #18 on: 17 February 2011, 10:35 »
vcds lite?
Offline danmusic24
Re: Obd problem
« Reply #19 on: 17 February 2011, 11:10 »
you aint aving much luck are yer mate :wink:
