Author Topic: Ecu immobiliser  (Read 1255 times)
Offline neil1780
Ecu immobiliser
« on: 11 February 2011, 17:16 »
If I plug another ecu into my car will the car start then cut out or will the immobiliser not let It fire at all? Got an ecu but can't get vagcom till tomorrow just wanted to try it.
V6 4MOTION
Offline mark-mk3gti
Re: Ecu immobiliser
« Reply #1 on: 11 February 2011, 17:40 »
hi mate, ive just changed my immob box and had to recode them, i am pretty sure itll just not start, and when you have vagcom youll see an error code relating to immob halting engine start etc
whats up with ur mk3?
Offline neil1780
Re: Ecu immobiliser
« Reply #2 on: 11 February 2011, 19:02 »
Car won't go mate there's a thread further down 8v won't spark kind of explains it all.
V6 4MOTION
Offline danmusic24
Offline neil1780
Re: Ecu immobiliser
« Reply #4 on: 11 February 2011, 19:36 »
Seen that mate got an ecu today think you can program them to immobiliser box with vagcom from what I've read on here.
V6 4MOTION
Offline danmusic24
Re: Ecu immobiliser
« Reply #5 on: 11 February 2011, 19:53 »
fair play! but just sure that whoever does it knows what they are doing...hope it works! good luck :smiley:
Offline mark-mk3gti
Re: Ecu immobiliser
« Reply #6 on: 11 February 2011, 20:28 »
It's not that hard to do, but u do need a registered version of vagcom to complete the process!
You would be best following the directions from Ross-tech site
Here's the link and post I got..
this is how you code a different ecu to your new immob box, just as it says near the bottom you click 'immobiliser' rather than 'instruments' in a mk3 :)
http://www.ross-tech.com/vag-com/cars/immobilizer2.html
Re: Ecu immobiliser
« Reply #7 on: 11 February 2011, 20:32 »
It will start and run for a very short time
Offline neil1780
Re: Ecu immobiliser
« Reply #8 on: 11 February 2011, 20:55 »
Cool will try it in the morning.
My mates a mechanic and he's doing the vagcom bit but will have a look at this.
V6 4MOTION
Offline mark-mk3gti
Re: Ecu immobiliser
« Reply #9 on: 11 February 2011, 21:03 »
Well done Wayne! Do you get a golden clock at 20k posts? :)
