Author Topic: 5x112 to 4x100 redrill:  (Read 4307 times)
Offline Jack3559
« on: 08 February 2011, 10:49 »
Is it safe?
Is it possible?
How much does it cost?
Will I need a sh¡tload of balancing weights?
Cheers.
 :kiss:
Re: 5x112 to 4x100 redrill:
« Reply #1 on: 08 February 2011, 12:00 »
Have seen wheels welded up and redrilled but it is not something I am keen on.
Why not run adaptors.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2 on: 10 February 2011, 10:25 »
Adaptors are expensive, but I'm going to make up some I reckon.
You can't run all 5 bolts, unless you make it a certain way. You'll see what I mean if you placed 4x100 and 5x112 on top of one another. I'll see if I can pull out the adaptor pic Danny found, its pretty complex and I'm not sure how reliable it is :(
Offline LazyLunatic
  • MK3 20VT Project
Offline wag,en,volks
  • I make wheels shiney ,pm for quotes
« Reply #4 on: 17 February 2011, 18:17 »
if offset isnt an issue get custom adaptors ,if it is then redrilling can be an option
Offline Mr Blue
« Reply #5 on: 04 March 2011, 10:37 »
We deal with lots of redrill's (split rims only)
Ive got two sets and is very popular. We are probably the only ones who will weld up non-flatbacks.
Mine required little or no weights and have not heard any bad reviews on the other sets as its done properly!
Prices vary from each set. You may also need a spiggot ring.
0788 88 31836. Bedford
