Author Topic: School boy error!!  (Read 1794 times)
Offline ashbreed
School boy error!!
« on: 07 February 2011, 19:24 »
I know I'm a tit before I get abused!!
I got a golf gti, 2.0 8v (2e engine code). I took the HT leads of the dizzy cap when puttin a new one on and for got the order they went back on....
Think I may have also tried to start the car with the leads on the wrong order so therefor the timings probably up sh*t creek bow aswell.
So basically could some one show/tell me the order it should fire and also how to adjust the cylinders so that if it is out of time I can put it back to normal!
Offline chubbs111
Re: School boy error!!
« Reply #1 on: 07 February 2011, 19:28 »
i cant help you with the posistion of the leads    but your timing wont be affected     just need to put leads on correctly
Offline Khare
  • The bear that khares
« Reply #2 on: 07 February 2011, 19:33 »
Timing won't be affected.
Follow the wires to the correct positions  :smiley:
Offline Bellend
« Reply #3 on: 07 February 2011, 19:34 »
Line it up TDC, with the marks on the camshaft pulley, wherever it is, that's number 1. Then go 1-3-4-2 in clockwise I THINK.
Anyone confirm?
Where all my moneys went.
Offline clivusdel
  • Mk3 Golf GTi 8v
« Reply #4 on: 07 February 2011, 19:35 »
my dizzy cap has the numbers stamped on it for the ht leads
Offline Khare
« Reply #5 on: 07 February 2011, 19:38 »
Anyone confirm?
Correct, number 1 being closest to engine wiring connector.
Offline Bellend
« Reply #6 on: 07 February 2011, 19:40 »
Anyone confirm?
Cool cheers.
Or just follow Khares pic tbh.
Offline ashbreed
« Reply #7 on: 07 February 2011, 20:50 »
super stuff! cheers for the quick replys! so if i put the leads back on in order then it will b ok? and the timing wont be affected?
Offline Khare
« Reply #8 on: 07 February 2011, 20:51 »
Why would timing be affected? You've not messed with the camshaft or the timing belt  :smiley:
Offline AudiA8Quattro
« Reply #9 on: 07 February 2011, 23:47 »
Or moved the distributor body?
