Author Topic: 8v gti no spark NEW PROBLEMS  (Read 3484 times)
Offline javalin
Re: 8v gti no spark
« Reply #20 on: 08 February 2011, 13:13 »
I am running the GSF one - and its works fine.  beware cheap imitiations I guess.
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline neil1780
Re: 8v gti no spark
« Reply #21 on: 08 February 2011, 13:45 »
£25 + vat from local Partco cause I know manager. :smiley:
V6 4MOTION
Re: 8v gti no spark
« Reply #22 on: 08 February 2011, 14:45 »
as long as its a good make should be ok, mine was completly unbranded
Offline neil1780
Re: 8v gti no spark
« Reply #23 on: 09 February 2011, 19:50 »
Changed crank sensor an still no spark! It's annoying me now! Where do the wires from the coil go to will need to check them tomorrow?
V6 4MOTION
Offline danmusic24
Re: 8v gti no spark
« Reply #24 on: 10 February 2011, 16:03 »
my crank sensor was shot! bare wires,and inturn shorted out my ecu took me ages to work it out...but that was the problem :wink:
Offline javalin
Re: 8v gti no spark
« Reply #25 on: 10 February 2011, 16:08 »
yeah - check for battery voltage (> +12v) on pins 1 & 3 on the coil feed.  Also check whilst cranking that 12v pulses seen between 2 & 3 on the feed.  You'll need a test light and/or multimeter for this
James
Offline neil1780
Re: 8v gti no spark
« Reply #26 on: 10 February 2011, 16:33 »
Cheers mate gonna check thes tonight got that info today.
Did you half to replace ecu then?
V6 4MOTION
Offline danmusic24
Re: 8v gti no spark
« Reply #27 on: 11 February 2011, 08:03 »
yes mate! one day my car just stopped it done my head in! i had no spark so replaced coil,dizzy,ripped out alarm and had it checked,replaced all plugs and leads and crank sensor which was in a bad way,turned out to be a earth fault on ecu due to crank sensor wires touching...when i plugged in vag com i got error message BATTERY + or something like that,basically ment no power to ecu...took me 3 months to find problem..some chap on here had a ecu with key(chip) imb,and ring leader for £75....plugged it all in and BINGO of she went :wink:
Offline neil1780
Re: 8v gti no spark
« Reply #28 on: 21 February 2011, 17:56 »
Ok now it's running I have a new problem. When I start the car from cold it runs for about 20-30 mins then cuts out. If I try to start it again it cuts out straight away but if I leave it for 5 mins it starts but only runs for about 5 mins, the colder it is the longer it runs. The fuel pump struggled a bit yesterday then stopped and the car cut out, so I thought the relay was dodgy (is new from vw) so I pulled it out tonight and linked it out with wire so the pump was live and it still cut out and the pump stayed on.
Anyone help?
V6 4MOTION
Re: 8v gti no spark NEW PROBLEMS
« Reply #29 on: 22 February 2011, 09:31 »
ecu relay would be next on the list. does sound a lot like the new crank sensor is faulty, as this is exactly what my cheap ass new one did...
