Author Topic: Failed mot :(  (Read 5465 times)
Offline Khare
  • The bear that khares
Re: Failed mot :(
« Reply #10 on: 08 February 2011, 10:40 »
Emission were suppose to be 0.3 but there at 6.8 through the roof
in that case i dont think Khares " fix " will be that much help  :laugh:
I didn't know it'd be over by THAT much!   :grin: :grin: :grin:
+1 with what wayne said , personly id steer clear of the old redex crap it can cause more problems inside the engine
I've always used Redex and it's great! Never caused any problems, car always ran smooth.
I've got a very good dyno curve and hp to prove it  :grin:
Offline Len
Re: Failed mot :(
« Reply #11 on: 08 February 2011, 11:37 »
Redex is great! Used it all my cars. Yes its been around a very long time!
I hate it when they wont give you any idea what the problem might be!
www.sas.org.uk
www.the-ace.org.uk
Offline AudiA8Quattro
Re: Failed mot :(
« Reply #12 on: 08 February 2011, 13:04 »
is there definitly a cat in there, i would expect it to be lower than that even with a duff cat. it seems way, way over though my ABF was something like 0.3-0.8 without a cat!
get your fault codes checked, i would suspect faulty ecu temp sensor or lambda.
Exactly what i was going to say, even without a cat the emissions are way to high.
Check the plugs, they are probably black. I would suspect ecu temp sender or lambda also.
For the record, if emissions are only slightly over, use cataclean, not redex, its much better.
Offline Craiglannon
Re: Failed mot :(
« Reply #13 on: 08 February 2011, 17:49 »
Goni stick it in a garage this weekend it's shuddering abit when drivin at about 30 35 mph hope it's not totally f***ed
There's also defo a cat there had a look earlier
also noticed a ripped hose dnt have a clue what it's for it goes in just above my oil filter and goes to a black box type this at front of engine doesn't seem to be anything in it tho
Offline Craiglannon
Re: Failed mot :(
« Reply #14 on: 08 February 2011, 20:48 »
Here's the figures just to show how bad it is
CO MAX- 0.30% ..8.92%
HC MAX- 200ppm... 270ppm
LAMBDA- 0.97-1.03.. 0.77
Offline javalin
Re: Failed mot :(
« Reply #15 on: 09 February 2011, 13:57 »
if I read that correctly, low lamda, high Hydrocarbens and high CO means its running rich and not fully combusting the fuel - i.e. mixture is wrong, or ignition is weak.  Would go with a coolant temp sensor change first.  Worth checking condition of ignition system (plugs, wires, dizzy cap & arm and sparks) if not serviced recently and replace the air filter if not recently serviced too.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Craiglannon
Re: Failed mot :(
« Reply #16 on: 09 February 2011, 15:05 »
Will take plugs out tonight give them a clean And order new ones anyway
cheers seems to e more helpful on this than askin a mechanic in the f***ing garage
Offline Khare
Re: Failed mot :(
« Reply #17 on: 09 February 2011, 15:27 »
Offline javalin
Re: Failed mot :(
« Reply #18 on: 09 February 2011, 15:39 »
nah - if its 1.8 or gti - VW spec 4 electrode ones - i.e.
http://cgi.ebay.co.uk/Volkswagen-Golf-MK3-4-5-Bosch-Super-Plus-Spark-Plugs-x4-/200561387701?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eb263e8b5
a touch more at ~£17 delivered.
Leads, cap and arm - would suggest from GSF - https://secure.gsfcarparts.com/shop/  (under ignition category).  Air filter also from GSF under "filters".
James
« Last Edit: 09 February 2011, 15:45 by javalin »
Offline Khare
Re: Failed mot :(
« Reply #19 on: 09 February 2011, 15:47 »
James
It's a 16v.
But it doesn't matter, the NGK ones I posted are triple electrode. I've always bought NGK plugs both for 8v and 16v and they've always been great.
