Author Topic: Failed mot :(  (Read 5468 times)
Offline Craiglannon
Failed mot :(
« on: 07 February 2011, 17:45 »
Got a mk3 golf gti 16v put it in for not today and it failed :(
basically the guy said the emissions were too high but didn't really give me an explination anyone had this problem before B could be the cat I suppose but not sure as can't really test it
also the abs light will not illuminate before starting
Anyone able to help here it's urgent :-/
cheers craig
Offline Khare
  • The bear that khares
Re: Failed mot :(
« Reply #1 on: 07 February 2011, 19:35 »
I would suggest sticking a full tank of vpower in there with a bottle of redex and giving it the italian tune up (not as extreme, but close).
You may find that it'll blow all the cobwebs out and pass  :smiley:
It may be a faulty coolant temp sensor as well.
Offline Craiglannon
Re: Failed mot :(
« Reply #2 on: 07 February 2011, 20:09 »
Cheers mate think it needs a good boot anyway been sittin about for a while will give it a go see what happens fingers crossed
Offline Seanl
Re: Failed mot :(
« Reply #3 on: 07 February 2011, 21:46 »
Also pull out the holder for airbag/abs and check the wires have not been snipped. Previous owner may have done it to hide an abs fault
Offline AudiA8Quattro
Re: Failed mot :(
« Reply #4 on: 07 February 2011, 22:33 »
How much were the emissions over by?
Offline Craiglannon
Re: Failed mot :(
« Reply #5 on: 08 February 2011, 08:44 »
Emission were suppose to be 0.3 but there at 6.8 through the roof
Re: Failed mot :(
« Reply #6 on: 08 February 2011, 09:44 »
I would think you have a lambda or temp sender problem.
Might also be the cat in trouble.
Offline JC
  • Back in the North.
Re: Failed mot :(
« Reply #7 on: 08 February 2011, 09:54 »
in that case i dont think Khares " fix " will be that much help  :laugh:
Offline mick ov mids
Re: Failed mot :(
« Reply #8 on: 08 February 2011, 09:59 »
+1 with what wayne said , personly id steer clear of the old redex crap it can cause more problems inside the engine
[img width=500 height=200]http://i836.photobucket.com/albums
Re: Failed mot :(
« Reply #9 on: 08 February 2011, 10:25 »
is there definitly a cat in there, i would expect it to be lower than that even with a duff cat. it seems way, way over though my ABF was something like 0.3-0.8 without a cat!
get your fault codes checked, i would suspect faulty ecu temp sensor or lambda.
