Author Topic: Another day another problem!!  (Read 2524 times)
dub268
« on: 06 February 2011, 23:58 »
Last couple days the car has been cutting out when driving  :shocked: i lose steering and braking and get battery light show up on dash. Now i do 1 of 2 things coast to a stop and restart car or drop it into 2nd and bump start and everything is fine again until next time it happens, checked vagcom no engine faults, all pipes/ leads are fine.
Any one with any ideas what this could be?
Cheers Michael
« Last Edit: 04 March 2011, 13:17 by dub268 »
Offline vwfiend
Re: Another day another problem!!
« Reply #1 on: 07 February 2011, 00:00 »
Alternator packing up mate?
dub268
« Reply #2 on: 07 February 2011, 00:14 »
forgot to say just before it cuts out i get hesitation when trying to accelerate, it wont rev past 1.5k in gear but take it out of gear and it will rev all the way to redline!
vwfriend ill test alternator in the morning
Offline Khare
  • The bear that khares
« Reply #3 on: 07 February 2011, 00:20 »
Sounds like the coil!
When in gear the engine has to work harder to push the car forward, hence the misfire.
I had the same misfiring when accelerating or at high RPMs. Eventually coil packed up and it wouldn't fire up again.
Offline MaXXeH
  • Golf MK5 GTI
« Reply #4 on: 07 February 2011, 00:26 »
i have had this prob also when my battery was on its last legs.
Test it with a muilty meter and make sure it is getting the correct charge when running.
Offline spetzdude
  • I Bleed Blue!
« Reply #5 on: 07 February 2011, 07:29 »
Does sound like a coil.........
Performance mods: Revo stage 2 map, 5 Peice Hose Kit, TIP, evoloution motorsport air filter, N249 by-pass, Forge spliter valve, lowerd 50mm (KW), Front & Rear Eiabach ARB, Full Milltek Turbo back exhaust.
Cosmetic mods: Tints,De-wiperd the rear, De-badged front grill, Sharan rear badge, Rear spoiler, 4mo rear valance, 4mo front spliter, arero wipers, stubby areial, DOTZ 18" Alloys, Boost guage, Smoothed Bumbers, ECS N75 Vlalve.
BHP: 231
TRQ: 341.3
Offline alexd
« Reply #6 on: 07 February 2011, 08:06 »
Had this it was my MAF
dub268
« Reply #7 on: 07 February 2011, 13:25 »
just happen again so called into my mates whos got vagcom aswell and this is what his showed up
Address 01: Engine
   Controller: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR HS D02
   Coding: 04000
   Shop #: WSC 00028
2 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
            P0116 - 35-10 - - - Intermittent
00544 - Maximum Boost Pressure Exceeded
Readiness: N/A
would this be the cause of engine cutting out?
Offline houston
« Reply #8 on: 07 February 2011, 16:44 »
temp sensor could be causing overfuelling (full choke) so maybe thats your misfire?
has your mate wiped them so you can retest and be sure there not old codes?
how longs it been since its had a service?
my first thought was maf, if it was alternator then it wouldnt have restarted, if it was bettery then thered be more signs of it dying
dub268
« Reply #9 on: 07 February 2011, 19:32 »
Yeah we've wiped codes so will see over the next few days if they come back, temp is old code that I know about but boost is a new one,  service is due 1700 miles.
« Last Edit: 07 February 2011, 19:57 by dub268 »
