Author Topic: Another day another problem!!  (Read 2527 times)
dub268
Re: Another day another problem!!
« Reply #10 on: 04 March 2011, 13:14 »
Stilling having problems with car stalling when driving, so hooked it up to vagcom again last night and found
Address 01: Engine
   Controller: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR HS D02
   Coding: 04000
   Shop #: WSC 00028
2 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
            P0116 - 35-10 - - - Intermittent
00544 - Maximum Boost Pressure Exceeded
Readiness: N/A
which is the same as last time, so ive done a little search around the net and found that 00544 is linked to a fault n75, would the n75 cause the engine to stall? :shocked:
If it is n75 which one is best to replace mine, as ive read J & H valves seam to be upgrade valves and c is stock replacement and where's the best place to get one from?
« Reply #11 on: 04 March 2011, 13:50 »
I would replace the temp sender as a first step.
dub268
« Reply #12 on: 04 March 2011, 15:57 »
I'll try get one over the weekend see what happens.
Offline houston
« Reply #13 on: 04 March 2011, 20:29 »
Could still be the maf too, have you tried unplugging it?
dub268
« Reply #14 on: 18 March 2011, 22:56 »
Well after a week or so of car behaving its started to play up again, so out comes vag-com and know it seams another problem has appeared
Address 01: Engine
   Coding: 04000
   Shop #: WSC 00028
2 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
            P0134 - 35-10 - - - Intermittent
Readiness: N/A
No im guess that is the lambda spitting it's dummy  :angry: and stalling the engine, any idea how much new sensor is and best place to get on from and is it easy enough to replace?
Offline houston
« Reply #15 on: 18 March 2011, 23:57 »
can get universal ones for about 20 quid from a motor factors, there easy to change if it comes out ok, but most of the time they can be a pig, best off just hammering a socket over the old sensor so you have more of a grip to take it off, wd40 it the night before your gonna work on it
