Golf mk2
G'day, newbie with a prob!
Topic: G'day, newbie with a prob! (Read 3539 times)
danrog
Just got here
02 March 2005, 13:17 »
Hi chaps and chapesses, I'm new to this but I have a prob with my golf gti and could do with some help. Recently it has started to cut out when the revs drop below 1000 rpm rather than bring it back up. I have had new spark plugs, leads, dizzy cap and starter motor fitted but the problem still perssists (it goes well as long as you are driving fast). Could it poss be an engine management prob, I would welcome any help from anyone who has experienced this or is a dab hand at gti's.
Ta much
Dan H reg mark 2 gti
mrwotto
Guest
Re: G'day, newbie with a prob!
02 March 2005, 13:23 »
Moved topic from new members section due to it being of a technical matter.
Welcome to the site anyway mate.
Sorry i cant be of any more help!
the Driver
GTI forum regular
smell it
02 March 2005, 22:57 »
of no help at all , but my driver does it all the time aswell, start her up no problems , come 2 first round about or junction , put foot on brake and clutch , and it stalls , the way round this ive found is 2 make sure uve got warm winter jacket and good battery in ure vw, personally i think its a sighn of a good mrk 2 if it likes 2 cut out
Blah blah blah Angledust
the Driver
GTI forum regular
smell it
02 March 2005, 22:59 »
my top tip of the day however is 2 look at the cold start up regulator , thingy, try unpluging it !
T1 VDUB
GTI forum regular
All work and no play makes Jack a dull boy
02 March 2005, 23:23 »
No offence guys but Im glad to hear its a common problem. My 16v MK2 doesnt always do it but occasionally, as you said, when approaching a stop likes to cut out. It starts immediatly... Maybe its the cold weather.
16 Valve
danrog
Just got here
03 March 2005, 11:38 »
Cheers peeps, it's good to know i'm not alone on this one!
Gambit
Forum addict
Reply #6 on:
03 March 2005, 11:59 »
reset the ECU and clean out the ISV *properly*
the Driver
GTI forum regular
smell it
Reply #7 on:
04 March 2005, 00:07 »
Nae bother
danrog
Just got here
Reply #8 on:
04 March 2005, 10:23 »
To clean the ISV properly, do you clean it with carb cleaner, then once its clear, spray some WD40 onto it?
Also, sorry to be a pain, when reseting the ECU, which end do you unplug the blue water temp sender, or do you take it off at both ends?
Dannyd
GTI forum regular
LOOK AT THAT VALVER GO!
Reply #9 on:
04 March 2005, 10:41 »
welcome! take the battery lead off for 20 minutes
wacked up on scuby snacks!
Golf mk2
