Author Topic: MK2 Rear Beam?  (Read 1359 times)
Offline Dmonday
MK2 Rear Beam?
« on: 06 February 2011, 21:37 »
MK2 Rear beam, would it fit a MK3 'state?
Dan
Re: MK2 Rear Beam?
« Reply #1 on: 06 February 2011, 21:39 »
Dan
I believe so yes, RJ could confirm 100% but I am sure only the 5 stud is different / wider.
Offline Dmonday
Re: MK2 Rear Beam?
« Reply #2 on: 06 February 2011, 21:41 »
Dan
Sweet, thanks Wayne :afro: want to convert to rear discs with the VR in but stick to 4x100 :)
Dan
Re: MK2 Rear Beam?
« Reply #3 on: 06 February 2011, 21:45 »
Dan
Dan
The beam is the same just the stub axles that are different.
Offline Dmonday
Re: MK2 Rear Beam?
« Reply #4 on: 06 February 2011, 21:48 »
Dan
Dan
Ah so would just need to swap the stub axles off mine and it's a straight fit?
Dan
Re: MK2 Rear Beam?
« Reply #5 on: 06 February 2011, 21:50 »
Dan
Dan
Dan
Nope I believe that mk2 Disc stub axles will bolt to your beam thus saving the hassle of changing it.
Offline Dmonday
Re: MK2 Rear Beam?
« Reply #6 on: 06 February 2011, 21:53 »
Ahh i see, would make life easier but i think i could save money by buying a full GTi beam and sort it all out while it's off the car and then do a straight swap one weekend so i don't have to worry about the bushes and everything, will have a look into it though thanks wayne!
Dan
Re: MK2 Rear Beam?
« Reply #7 on: 06 February 2011, 21:55 »
No worries  :smiley:
Re: MK2 Rear Beam?
« Reply #8 on: 07 February 2011, 14:31 »
if the estate uses the same beam as a mk3 hatchback then yeah straight swap.
4-5 stud disc stub axles, calipers and carriers all the same, just the discs that are different. later spec mk3 use better calipers without an external handbrake spring so use some of those if you can. for the cables you want MK3 GTI if going for rear discs :)
