Author Topic: Camber - The cheap way.  (Read 41266 times)
Offline Dmonday
Re: Camber - The cheap way.
« Reply #40 on: 10 February 2011, 20:22 »
so the next question is how much camber can these shim produce... ill skip over to the other thread now :D
Proper shims i believe are 3 degrees of negative camber, someone correct me if im wrong :)
Dan
nope, i believe at max they are -1.5 degrees, you need 2 shims to get 3 degrees, although you can adjust toe at the same point too
That's it, i thought it was 3 because my mate doubled them up :rolleyes:
Offline Diamond Hell
  • Opinions я Us
Re: Camber - The sh!t way.
« Reply #41 on: 27 February 2011, 13:15 »
Obviously this is a modification that anyone doing is declaring to their insurers, right?
If you're not then you're running around with invalid insurance and frankly any insurer would be mad to insure a car with this modification as it's screwing all of the fitment of two out of four contact patches on the road.
I'm blown away that anyone would do such a stupid, dangerous modification, let alone publicise it on a forum.  :rolleyes:
Offline robz
« Reply #42 on: 27 February 2011, 13:48 »
Took you a while to see this didn't it :D
Offline Gash
« Reply #43 on: 27 February 2011, 14:00 »
Well i picked up shims for 12 quid so!
Offline Dmonday
« Reply #44 on: 27 February 2011, 19:29 »
Show use only, i was asked how to do it and create a guide.
  • Opinions я Us
« Reply #45 on: 28 February 2011, 13:41 »
Turns out my moron detector was on low-power.
Offline AudiA8Quattro
« Reply #46 on: 28 February 2011, 16:49 »
I thought it beeped constantly  :tongue:
Offline Dmonday
« Reply #47 on: 28 February 2011, 18:01 »
N'aww
Offline lemski
  • 16v
« Reply #48 on: 28 February 2011, 19:35 »
tbh who ever does it for the road its upto them to run it like that, like its up to us all when doing stuff to the car and altering from standard. i thought it was a good guide dan.
Offline bored_Welsh_lad
« Reply #49 on: 03 March 2011, 21:21 »
So please tell what is so dangerous about these, apart from the fact that you can adjust the toe and camber of your car when lowered... So in fact you can correct geometry and make a car handle much better if you had 4 wheel alignment...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
