Author Topic: Camber - The cheap way.  (Read 28570 times)
Offline Dmonday
« on: 06 February 2011, 20:20 »
Warning: If you use this method on the road, you will crash and instantly burn to death.
As a few of you where asking for a quick write up on using washers for camber, i'm running rear drums at the moment but it will be the same for rear discs and if you can't remove the rear discs / callipers you shouldn't be doing this :)
All you will need is a couple of M10 or M12 washers (i think it's M10)
Full Size: http://i71.photobucket.com/albums/i122/dannymonday/DSC06640.jpg
First thing you'll need to do (obviously) is stick some wood / a brick in front of the front wheels and take the hand brake off, jack the rear end up and take the wheel off.
Full Size: http://i71.photobucket.com/albums/i122/dannymonday/DSC06633.jpg
to see this
Full Size: http://i71.photobucket.com/albums/i122/dannymonday/DSC06634.jpg
Take the pin out and the cover off should have a large nut behind that, won't be too tight so just need to take that off
Full Size: http://i71.photobucket.com/albums/i122/dannymonday/DSC06636.jpg
Then take the washer and wheel bearing out should have these below out so far
Full Size: http://i71.photobucket.com/albums/i122/dannymonday/DSC06637.jpg
Pop the hub off (should come straight off with the hand brake off)
Full Size: http://i71.photobucket.com/albums/i122/dannymonday/DSC06638.jpg
should see this ring above, might take a few taps or a little tug with mole grips to pop it off
Full Size: http://i71.photobucket.com/albums/i122/dannymonday/DSC06639.jpg
Due to my bolts being rounded off can't get any more pictures but it's pretty simple from here, take the bottom two bolts fully out and loosen the top two off to get enough room to slip washers under the bottom two bolts.
A washer needs to go under the bottom left bolt on the picture, if you want more camber you want two washers under the left bolt and one under the bottom right, this stops you having as much toe.
I'm not recommending you do this as you will almost definatly crash and burn to death as i know some people will point out, but i'm using this method find with standard bolts and hundreds of other people are so any questions, i'll try and answer them for you :)
Dan
« Last Edit: 09 February 2011, 16:17 by Dmonday »
Offline robz
Re: Camber - The cheap way.
« Reply #1 on: 06 February 2011, 20:30 »
Perfect dan!!
Can't wait till tue morning!!
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
« Reply #2 on: 06 February 2011, 20:38 »
Wasnt that long ago I had them rear shoes fitted  :grin:
Golf Gti
Offline Dmonday
« Reply #3 on: 06 February 2011, 20:46 »
:D Going to give her a good clean up once i've finished the conversion, it's from being sat for so long :(
Dan
Offline Gash
« Reply #4 on: 06 February 2011, 20:55 »
awesome!
so to get some camber one washer will be fine? :)
Offline Dmonday
« Reply #5 on: 06 February 2011, 21:06 »
awesome!
Yeah dude :) just put one on the front / bottom left bolt so that will reduce the toe!
Dan
Offline Gash
« Reply #6 on: 06 February 2011, 21:10 »
just so im not a knob and cock up
one 1-2mm m10 washer here
Offline Dmonday
« Reply #7 on: 06 February 2011, 21:34 »
Yep :)
Offline Gash
« Reply #8 on: 06 February 2011, 21:40 »
awesome looks like im going to be spending more money again haha
just spend £40 on wheel nuts :(
Offline Dmonday
« Reply #9 on: 06 February 2011, 21:42 »
for two washers!? Could probably find them in your shed / garage / house :D or like 20p from a hardware shop.
Dan
