Author Topic: flared arch vs plastic arch  (Read 7635 times)
Offline tweed
« on: 05 February 2011, 17:52 »
Right had a look on archenemy and I need to flare them all round, not so much on the front though.
So can you stick the plastic arches back on if they are flared?
If it helps wheels are 16x8 et20 and 16x9 et21 so that will give you a idea on how much the arch need work.
Offline gover87
  • mk3 gti 16v
Wheel colour um ar???
« Reply #1 on: 05 February 2011, 18:57 »
Do u mean rolled arch mate? If so i dont see why u cant trim the plastic arch lip and stick them on, sikkaflex is best ive found, its windscreen sealer but dries hard as rock. If u mean flare the arches then it will prob mishape for the plastic trim unless u heat it to shape
Offline jonnypolish
  • t2871r needed :)
Re: flared arch vs plastic arch
« Reply #2 on: 05 February 2011, 19:01 »
Dont think you can slap the plastic trim back on if you "Flare" the arches
Although if you find out you only need to roll then you can slap em back on!
By the way the wheels are STUNNING!!
 MK2 VR y0!
« Reply #3 on: 05 February 2011, 20:19 »
If you have them rolled they can be refitted however if you have them pulled / flared they will not refit.
Look better without them.
Offline robz
« Reply #4 on: 05 February 2011, 20:26 »
Keep em on! Better!!
Offline gover87
  • mk3 gti 16v
« Reply #5 on: 05 February 2011, 21:07 »
I think (but might be wrong) that if u flare them then clamp the plastic arch and heat it it in the right places it would work, not sure how it would match up with the door trims etc though. Just a thought mate
Offline tweed
« Reply #6 on: 06 February 2011, 15:17 »
Thanks for the replies  :wink:
Well I looked on archenemy and they had to put on a stubble flare on a mk3 with 16x9 et15 so hopefully I can get away with rolling as I'm 6mm closer in.
And I want cl/gl trim but can't get any  :cry: anyone want to sell me theirs?
Or if you find some I'll give you £10 on top of what you get them for.
Offline Bellend
« Reply #7 on: 06 February 2011, 16:56 »
What you after mate?
Got 5 door coloured GL trim and some CL plastic trim. You after the ends?
Where all my moneys went.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #8 on: 06 February 2011, 17:18 »
mine are rolled and flaired and im down 100mm, more pics on my dubride thread but here is how mine looks
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline shepgti
« Reply #9 on: 06 February 2011, 19:08 »
pretty sure your not running 16x9 et21 though kells :rolleyes:
