Author Topic: changing front pads (1.8 gl N)  (Read 1383 times)
Offline darcy
« on: 04 February 2011, 12:14 »
had the pad for sometime now but still not changed.
what tools do i need and do the calipers have to be removed or do they split?
asking as i dont really have the space or tools to do it so will need to find some somewhere.
cheers D
Offline Deano2711
  • 1992 VR6
Re: changing front pads (1.8 gl N)
« Reply #1 on: 04 February 2011, 12:17 »
The caliper does not need to come off, undo the bottom bolt and it just lifts up enough to remove the old pads. You will then need a caliper winding tool to open it up for the new pads.
Offline Dmonday
« Reply #2 on: 04 February 2011, 12:22 »
cheers D
Pretty easy job, just whip the wheel off and the calipers / carriers are seperate, just unbolt the caliper and slip that off (you will need to hold the inside bolt with a spanner while you undo the outside bolt with a socket / spanner) and the pads just pop straight out of the carrier, stick a bit of copper grease on the back of the pads and should be sweet :) i'm sure i will have missed something out but i jsut replaced my 1.8 8v brake setup with the VR / G60 brakes lastnight and it's simple stuff ;)
Dan
Offline Dmonday
« Reply #3 on: 04 February 2011, 12:27 »
Beat me to it :D although it does only take 5 mins to whip the caliper off (not carrier as their most likely seized :rolleyes:) is the caliper winding tool for the brake piston?
Dan
« Reply #4 on: 04 February 2011, 13:18 »
dont need a caliper tool, a g clamp will do the job. take the lid off the fluid reservoir or open the bleed nipple a bit. keep an eye on brake fluid level as you compress the piston, it will go up a bit.
oh and you cant just undo 1 bolt if its got 239mm brakes, you gotta take em both out
