Author Topic: how to remove my gti mk3 clocks from the dash  (Read 5383 times)
Offline tote
« on: 01 March 2005, 12:43 »
Hi ok i got some white dials for my mk3 gti 8v now how do i remove the dials so that i can put this ones please help.
« Last Edit: 02 March 2005, 07:59 by tote »
LIFE IS TO SHORT NOT TO.....!!!
Offline gti monkey
Re: how to remove my gti mk3 clocks from the dash
« Reply #1 on: 03 March 2005, 03:33 »
hey tote,
sorry dont have an answer for you, i just want a sportier dash too!
can you tell me where you got yours? there not just inserts are they? also does anyone know
if the mark 4 dash will happily swap places?
Offline golfyjammer
  • www.vag20v.net
« Reply #2 on: 21 April 2005, 22:29 »
you need to take off all the surrounding plastic bits, air vents and stuff.then you will see screws holding the surrounds on. once you have all this off?? you will see the clocks set back. undo the screw either side, tilt the clocks forward, squeeze your hand behind and take electric plug out, then simply unclic from the locators. be very careful. anymore probs let me know??    :wink:
Built by Germans, Thrashed by the English!
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 22 April 2005, 13:23 »
gti monkey. no dash willl another car without a certain amount of work!
Offline dazultra
« Reply #4 on: 07 May 2005, 17:50 »
Its a matter of a few screws to get the unit out:
1) Take off the panel to the right of the headlight switch (the ABS/airbag thing) and take out the headlight switch to reveal a screw to the left of it.
2) Take off the panel to the right of the radio which would house the heated seat switches if you have them to reveal another screw.
3) Remove those 2 screws and you should be able to remove the plastic surround from the main dials unit
4) This will reveal 2 more screws either side of the main unit - remove these and the unit can be removed - but first you have to disconnect the fat connector at the back, situated roughly above the speedo at the top left.
5) Then its just a case of taking the unit apart to get to the dials  :cool:
Hope this helps...
foilist2000
« Reply #5 on: 11 May 2005, 20:52 »
If you are looking for different colour dials try looking in the scrappies for a silver set from an ibiza gti, they slot straight in and if you make a hybriid of the golf/ ibiza clocks then they work perfectly.
I got a set for a fiver from the local boy.
Jason
