Author Topic: Pollen filter  (Read 2345 times)
Offline Bakesy
Pollen filter
« on: 01 February 2011, 20:37 »
Hi,my drivers foot well is very wet which is making the windows steam up and even freeze on the inside.I have been told it could be the pollen filter,but would this because the filter is faulty or full?
Offline tech1889
  • Mk2 GTI FTW !!
Re: Pollen filter
« Reply #1 on: 01 February 2011, 20:57 »
pollen filter housing is split  :wink:
Offline mcgee9t2
Re: Pollen filter
« Reply #2 on: 01 February 2011, 21:02 »
or after its been replaced the pollen filter cover hasnt been put back on properly.
Offline tech1889
  • Mk2 GTI FTW !!
Re: Pollen filter
« Reply #3 on: 01 February 2011, 21:04 »
as above can also be the problem but the cracking of pollen filter is a common fault on mk4's remove it all and have a look..
Offline Bakesy
Re: Pollen filter
« Reply #4 on: 01 February 2011, 21:09 »
Ok,thanks for the advise....is this the most likely cause of the well being wet?
Offline tech1889
  • Mk2 GTI FTW !!
Re: Pollen filter
« Reply #5 on: 01 February 2011, 21:11 »
its a definite possibility..
Offline mcgee9t2
Re: Pollen filter
« Reply #6 on: 01 February 2011, 21:17 »
could be other things but ide say pollen filter, defanitly be the first thing ide check as its a 2 minuit job to check. and if it does need replacing its not very expensive. if its not that it could be things like door seals ect.
if your not sure on how to check the pollen filter have a search for how to replace the pollen filter, but just use that as a guide of how to get the polen filter out and have a look at the filter and the cover/ housing for filter just to make sure theres no cracks anywere and have a look that the cover is compleatly on before you take the filter out, should be able to check tomorow before you set off for work/college/what ever it is you do/ when ever you have 5 minits spare.
Offline mr 1.8t dubbster
Re: Pollen filter
« Reply #7 on: 01 February 2011, 21:36 »
mine sometimes freeze inside too on a really frosty morning, how would you go about checking ie where is it?  :undecided: lol thanks
Forge Splitter, Smothed Airbox, Re-map and coilovers next.
Offline mcgee9t2
Re: Pollen filter
« Reply #8 on: 01 February 2011, 22:30 »
open bonet, top of bonet just below windscren, passenget side i belive.
as said do a search, few topics not so long ago about it with all the cold weather
Offline Rhyso
Re: Pollen filter
« Reply #9 on: 02 February 2011, 08:42 »
Once you've found the leak you're going to have to strip the interior and dry it out otherwise it will continue to mist / freeze up
