Author Topic: Pollen filter  (Read 2349 times)
Offline Bakesy
Re: Pollen filter
« Reply #10 on: 02 February 2011, 18:05 »
Checked filter this morning and was bone dry without any signs of cracks etc.Gutted now where do i look? :sad:
Offline T_J_G
Re: Pollen filter
« Reply #11 on: 02 February 2011, 18:20 »
It's almost as if someone needs to write a bit on leaks for the maintenance section.
:rollseyes:
Offline richw911
Re: Pollen filter
« Reply #12 on: 02 February 2011, 21:20 »
:rollseyes:
 :grin:
Offline Phil18t
Re: Pollen filter
« Reply #13 on: 03 February 2011, 20:44 »
how wet is the carpet? it could just be the water off the bottom of ur feet wetting the carpet and not having time to dry out because of the cold weather?? i found the same thing with mine, so i just drive round with the heaters on the footwell setting to keep it dry..tho u do get warm feet..either that or your drivers door membrane on the metal cover that holds the window reg in is leaking?
