Author Topic: what suspension  (Read 1438 times)
Offline mustang
  • 2Litre 8v Gti
what suspension
« on: 27 February 2005, 19:14 »
Right i,ve just fitted a set of 17"alloys with 205/40/17 tyres now i need to sort out the suspension,so what? i want to know is do i just fit lowered springs or go for a full set up shocks aswell, i only want to lower it by about an inch or maybe a fraction more but i dont want the tyres to rub any help would be helpful,also does anyone know of anyone in the kent area that could do the job without ripping the arse out of it cheers? ?:smiley:
Mick Mk3 Gti 8v,standard but not for long
Offline carl
Re: what suspension
« Reply #1 on: 27 February 2005, 21:11 »
 if you cannot get the coilovers for it i would recommend both spring and shortened dampers try venommotorsport they are cheapest ive got fk coilovers on my mk3 lowered 70mm with same tyres as youres no arch mods and no rubbing hope this helps.
mrwotto
Re: what suspension
« Reply #2 on: 27 February 2005, 21:18 »
I would recomend getting a full lowered suspension kit as the stock dampers arent designed to run shortened springs.
I got my lowering kit for ?250, and mine is dropped 40mm.  Would recommend that you dont get it dropped to much if you live near any speedbumps
Offline mustang
  • 2Litre 8v Gti
Re: what suspension
« Reply #3 on: 01 March 2005, 19:42 »
thanks guys for the help, i probably wont drop it to low as my whole area is dotted with speed humps its abit like a plague of the measels,every time you turn round theres another one,cheers again.
