Golf mk4
Wazzzer
K04 HELP please some one :S
Topic: K04 HELP please some one :S (Read 3707 times)
Nathan.golf
31 January 2011, 17:26 »
Does my engine code really matter to the s3 turbo i use? and would a s3 quattro turbo/manifold/oil return line and other bits and bobs work or not?
cheers
tech1889
Serious forum addict
Mk2 GTI FTW !!
Re: K04 HELP please some one :S
31 January 2011, 17:28 »
im not sure the oil return lines will fit... manifold should bolt striaght up.. need downpipe as well..
Mk4 Golf GTI anniversary and mk6 golf tdi
Nathan.golf
31 January 2011, 17:30 »
you hear about engine code this engine code that but i wana know if that makes a diffence to turbo/ manifold fitting?
i cnt see really see it
Hulmie
White MK4 1.8T AGU K03s
31 January 2011, 17:32 »
a k04-023 for example - the turbo and manifold what came off the car will fit a mk4 golf. The difference is how the turbo fits to the manifold.
The only turbo's that can use the standard mk4 1.8t manifold are K03, K03s and K04-001.
Nathan.golf
31 January 2011, 17:38 »
well i have some parts allready i just need turbo, manifold and oil pipes. just finiding em
will s3 manifold bolt on to my 1.8t block?
tech1889
Mk2 GTI FTW !!
31 January 2011, 17:40 »
if thats the case get a k04-001 turbo then no need for new manifold so saved money there.. but would need new oil lines.. not sure if the S3 ones fit..
Hulmie
Reply #6 on:
31 January 2011, 17:42 »
if i was off K04 then i wouldnt bother with a k04-001, i would just get a K03 turbo and send it off for a hybrid conversion using K04 internals of the turbo used on a rs6
Nathan.golf
Reply #7 on:
31 January 2011, 17:45 »
i just found out the s3 quattro is a v5 enginge the turbo is a k04-023.
the guy says he not sure if the manifold would fit but he says i could buy one that would? im getting confused lol
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Reply #8 on:
31 January 2011, 17:47 »
5v not V5
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Reply #9 on:
31 January 2011, 17:48 »
the manifold will bolt to the Golf head as they are the same engine
Golf mk4
Wazzzer
