Author Topic: K04 HELP please some one :S  (Read 3711 times)
Offline Nathan.golf
Re: K04 HELP please some one :S
« Reply #10 on: 31 January 2011, 17:50 »
cheers so let me get this clear, audi s3 quattro turbo/manifold will fit golf 1.8t 20v :)
Offline Nathan.golf
« Reply #11 on: 31 January 2011, 17:52 »
right so the s3 quattro turbo and manifold will fit my 1.8t 20v :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 31 January 2011, 17:58 »
yes they will physically fit
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #13 on: 31 January 2011, 18:09 »
what you have to remember though is its alot more work than just fitting a k04-023 turbo and manifold, you need oil and water lines to fit. a custom downpipe so that it'll meet up with your cat back exhaust, you'll need injectors upgrading to get the most out the turbo and the s3 ones wont fit the AGU, then you'll probs need to upgrade your fuel pump to get enough fuel to the injectors, you'll also need a FMIC and poss bigger maf housing and then get it all mapped. Alot of work and money.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 31 January 2011, 18:23 »
Amen
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #15 on: 31 January 2011, 18:25 »
+1 on that
Offline houston
« Reply #16 on: 01 February 2011, 10:07 »
power output from k04-001 and 023 are different, 001 is a straight fit but its only good for another 10bhp over the k03s.
if your upgrading to any turbo then the downpipe needs changing as its the biggest restriction, its just if your fittin an 023 then the downpipe has to be custom
Offline vwprime
« Reply #17 on: 01 February 2011, 10:47 »
+2
If you ahve the time and the mony to do this mate then will be nice but like what Hulmie said before you could always hybrid yours and save you all the flaffing around trying to get things to fit, like down pipe and lines.
TRANSFORM, & ROLL OUT!
Offline Hulmie
« Reply #18 on: 01 February 2011, 10:59 »
the K04-001 offers more than just 10bhp, it makes the torque more sustainable, better spool up and with good supporting mods could make upto 20bhp more than a k03s.
Offline Nathan.golf
« Reply #19 on: 01 February 2011, 13:31 »
mine is aum, will s3 injectors fit this?
i dont mind spending money cus im goin get parts and fit and remap when i get the money. i guna get downpips done at local custom exhaust place oil and water lines coming with turbo and manifold. also s3 injectors are chucked in along with seals bolts and gaskets.
would the s3 fuel pump fit. and will i need a 4bar fpr?
