Author Topic: Starting & Cutting Out Still  (Read 3570 times)
Offline clivusdel
  • Mk3 Golf GTi 8v
« on: 30 January 2011, 12:21 »
help...... again please???
i have had some starting problems on my mk3 gti 8v
it will start & suddenly cut out, it does this about 3 or 4 times before it starts ok
i was advised it may be the ecu relay (no30), so i bought one and changed it
but it hasnt made any difference
any more ideas more be a great help
Re: Starting & Cutting Out Still
« Reply #1 on: 31 January 2011, 14:29 »
what engine code and year is it
Offline clivusdel
  • Mk3 Golf GTi 8v
« Reply #2 on: 31 January 2011, 14:33 »
its a 94. not sure about engine code.
where would i find that?
cheers
« Reply #3 on: 31 January 2011, 15:34 »
prob easier to get us the part number off the ecu. basically i suspect theres a problem with the factory immobiliser, though usually its only on 96 cars. but if we can get part number off ecu that'll confirm it either way :)
other things it could be is damp in the dizzy cap or leads, faulty cap arm or leads, faulty coil, or maybe a dodgy crank sensor.  its worth cleaning out the throttle body as well
Offline clivusdel
  • Mk3 Golf GTi 8v
« Reply #4 on: 31 January 2011, 16:29 »
new dizzy cap & arm
new plugs
t/body & air intake all removed & cleaned out
it does have symtoms of immobilisor, but i dint think it had one?
Offline VWstevo
  • I feel The Need or Speed
« Reply #5 on: 01 February 2011, 16:15 »
sounds like a sensor, dose it cut out when hot and wont start until it as cooled down
Offline clivusdel
  • Mk3 Golf GTi 8v
« Reply #6 on: 01 February 2011, 18:34 »
no
it does either when first started, or if i drive up road to shop, stop it, then it does it again.
so it does hot and cold really.
« Reply #7 on: 02 February 2011, 13:30 »
does it have an isv?
Offline clivusdel
  • Mk3 Golf GTi 8v
« Reply #8 on: 03 February 2011, 18:09 »
sorry
whats an 'isv'?
« Reply #9 on: 04 February 2011, 09:25 »
does it look like this:
or more like this (its a mk2, but mk3 is similar, isv is the metal tube thing between the rocker cover and the inlet):
