Author Topic: aerial  (Read 2773 times)
Offline chubbs111
aerial
« on: 29 January 2011, 15:48 »
hi guys mk3 gti    rear roof mouted aerial  which way does the cable travel    to the front under the roof lining    or does it come to rear
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
Re: aerial
« Reply #1 on: 03 February 2011, 01:45 »
i suspect it runs towards the passenger side and then through the upper part of the roof on that side under the plastics and then down the passenger A piller, behind the glove box and to the radio.
Altho, to perform a check for this...the glove box and assembly around it come off pretty easy..just a couple of screws...so you can remove it and have a look for the aerial ther to see whether it is travelling in at that side...if so..then that gives you a means to track its pathway to the rear;-)
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
