Author Topic: mk3 gti 2.0 8v 1997 wont idle!!!!  (Read 1597 times)
Offline landylover83
« on: 29 January 2011, 13:07 »
hi all, i am struggling with my golf now!!!
will only run with foot on accelerator, soon as i come off it stalls, the accelerator cable under the engine bay where it goes onto the inlet, the what i can only think is the idle controller or something is constantly moving and not setting itself,
ANY HELP WOULD BE SOOPER!!!
07590 525 535 James
Offline Mike87Turbo
Re: mk3 gti 2.0 8v 1997 wont idle!!!!
« Reply #1 on: 29 January 2011, 13:16 »
Check all your vacuum/breather pipes for splits. Sounds like you've got an air leak somewhere to be honest!
« Reply #2 on: 29 January 2011, 13:25 »
would that make the stepper motor not set itself right tho?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 29 January 2011, 20:51 »
Clean the throttle body for starters.
Offline VWstevo
  • I feel The Need or Speed
« Reply #4 on: 01 February 2011, 16:19 »
07590 525 535 James
clean the carb with carb cleaner loads of it and see how that goes my have carbon build up
Offline harlemex
« Reply #5 on: 01 February 2011, 16:23 »
07590 525 535 James
Problem there is it doesnt have a carb.  :grin: :lipsrsealed:
« Reply #6 on: 01 February 2011, 19:48 »
Read my above comment.
Offline javalin
« Reply #7 on: 02 February 2011, 09:30 »
depending on the engine, he probably doesn't have a ISV either.
Yup, check for air leaks, clean the throttle body and if all else fails - http://javalins.wordpress.com/vw-golf-mk3/troubleshooting-common-fixes/ and http://www.golfgtiforum.co.uk/index.php?topic=101400.0
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
