Author Topic: How To: Install A Boost Gauge on a 1.8T  (Read 31363 times)
Offline Rhyso
Offline James Q
Re: How To: Install A Boost Gauge on a 1.8T
« Reply #1 on: 29 January 2011, 13:03 »
YAY!!!! :grin:
Offline Rhyso
« Reply #2 on: 30 January 2011, 19:44 »
Offline stfc_gti
« Reply #3 on: 16 July 2012, 09:45 »
this ones next on the list, not looking forward to it :-)
2002 1.8T GTI AUM, Standard (not for much longer)
jockgti
« Reply #4 on: 16 July 2012, 10:18 »
its easy mate if i managed anyone can
Offline stfc_gti
« Reply #5 on: 16 July 2012, 11:36 »
im ok up until the electric part, that the bit that worries me :-)
Offline Dalo Harkin
« Reply #6 on: 16 July 2012, 12:38 »
Its easy, your only adding an additional line into an already fused line  :wink:
jockgti
« Reply #7 on: 16 July 2012, 18:47 »
mine came with a small splitter thing was dead easy
Offline brewey
« Reply #8 on: 27 June 2013, 23:29 »
I know this is an old topic, but I thought I would add my 2p.
Before installing my gauge I read a lot of how to guides which were all helpful but none really explained the best/ easiest route for the silicone hose into the car. I wanted to make sure that I did not have any water ingress into the cabin so set about removing the glove box to get a better look at the bulkhead.
Upon removal I saw an unused grommit which led into the pollen filter bay, I simply drilled a hole in the grommit slid it over the pipe and then reseated into the bulk head. From within the pollen filter bay I then ran the pipe down the plastic cowling that goes into the engine bay (the curved plastic directly behind the airbox) which has a hole I'm the bottom then fed to the FPR.
Sorry I don't have any pictures but I was trying to be quick.
Hope this helps someone.
2000 1.8T ARZ - OEM+
