Author Topic: Backlit dials GROUP BUY - Please read first post for info.  (Read 14272 times)
Offline Jimmy Filth
Re: Backlit dials GROUP BUY
« Reply #60 on: 01 February 2011, 16:38 »
If it's not too late...
1.Tshirt2k - 16V, Design 3, white, 7.5k, 0-160mph, N, N
2. Boola -16v, design 3, blue, 7.5k, 0-160mph, N, N
3. Jimmy Filth 16v, design 4, blue, 7.5K, 0-160mph, N, N
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
7R 5 door.  Limestone Grey.  19" Pretoria's, Leather, DCC, Winter pack, keyless entry, rear camera.
Offline tshirt2k
  • Been there...Done that...
Re: Backlit dials GROUP BUY. Not Likely
« Reply #61 on: 01 February 2011, 18:32 »
Is it not a legal requirement for UK cars to have both MPH AND KPH. My next question was then, could you ask the suppliers about this as it is you that has (or rather tried) to organise this and therefore you are the suppliers contact.
Good point. I have looked it up and apparently it is for imported cars. Although it's not usually checked on MOT.
I have asked the question and I'm awaiting an answer.
Mk3 ABF 16VT Megasquirt V3
Offline tshirt2k
« Reply #62 on: 01 February 2011, 19:26 »
Updated
3. Jimmy Filth 16v, design 2, blue, 7.5K, 0-160mph, N, N
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
« Last Edit: 01 February 2011, 19:41 by tshirt2k »
Offline Jimmy Filth
« Reply #63 on: 01 February 2011, 19:28 »
Haha, yeah, I meant design 2...
Offline tshirt2k
« Reply #64 on: 01 February 2011, 19:42 »
Updated
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #65 on: 01 February 2011, 20:07 »
Here you go Slick:  :wink:
Motor Vehicles (Con & Use) Regs, 1986 Reg 35
Motor Vehicle shall be fitted with a speedometer which, if the vehicle was first used on or after 1.4.1984, shall be capable of indicating speed in BOTH miles per hour and kilometers per hour, either simultaneously or, by the operation of a switch seperately.
Except, vehicles max speed not exceeding 25 mph, motor cycle n e 100 cc, invalid carriage, fitted with tacho, etc, etc.
END.
Jonathan.
« Reply #66 on: 01 February 2011, 20:21 »
END.
Jonathan.
I guessed that was the case, spot on as always Jonathan
Offline tshirt2k
« Reply #67 on: 01 February 2011, 20:30 »
That's why the question was asked to the company.
Offline _redders_
« Reply #68 on: 01 February 2011, 20:49 »
wiring these in...
basically, the dials are powered by an inverter... the inverter is powered by any 12v supply, obviously, you only want the inverter to be "on" when the lights are on...
SO...
heres where you wire the pos and neg from the inverter... any switch in your car that lights up when you turn the lights on will have a grey/green wire, or a grey/blue wire... every one, the headlight switch, window, mirror, heater controls etc etc, this is the pos, and all these will have a brown wire... the earth, you can splice the pos and neg into any of these, and it will work perfect, OR you can find a pos and neg on the circuit borad and solder the pos and neg from the inverter to the board, so the clock can be removed if needs be as one whole unit. EASY :)
sorry if i offended anyone, but 4 pages of people either saying they cant afford these or there not worth the money is pointless, these dont get made in MPH, this i why he has sorted a group buy, there are no other dials like this out there, with this kind of selection available, the only other plasma dials like this available are DDI dials, and they come in at about £110...
on the subject of showing both KPH and MPH, well, its up to you really isnt it, but i can name a butt load of companys who offer dials throught the uk with only MPH readings... Premier dials, DDi, Lockwood, etc etc, if you MOT'er moans, then take it else where, as if hes gonna fail you for that, then your gonna fail where ever!
« Last Edit: 01 February 2011, 20:50 by _redders_ »
DROP IT LOW . . . ROLL IT SLOW
Offline Jimmy Filth
« Reply #69 on: 01 February 2011, 20:57 »
as far as the legality goes, I've got cars through MOT's that have only shown mph with no issues.  I also spoke to a good friend who is a traffic Officer and he said that as far as he's aware they can't do anything about it even if it was illegal as there are no powers from their point of view.
There is no law against it, only rules apparently.
