Author Topic: Silicone piping (Charcoal canister)  (Read 1371 times)
Offline ian007miles
« on: 27 January 2011, 23:33 »
Hi does any one no if I can replace the original black rubber pipe that come off of the top throttle body That goes to the black box Thingy( charcoal caniser). With normal blue silicone hose(like you would use on the top of the dump valve but with bigger interal diameter obviously lol) or does it have to be oil resistant? Thanx ian
« Last Edit: 28 January 2011, 02:37 by ian007miles »
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline tech1889
  • Mk2 GTI FTW !!
Re: Silicone piping
« Reply #1 on: 27 January 2011, 23:39 »
by black box thingy do you mean intercooler bud ?? you can get a forge version i believe..
Offline ian007miles
Re: Silicone piping
« Reply #2 on: 27 January 2011, 23:47 »
Na mate the black box in-between the header tank and the screen wash bottle it's the little pipe on the top of the throttle body. Its the box Thingy that has the little valves on top
Offline GunnerCP
Re: Silicone piping
« Reply #3 on: 28 January 2011, 00:16 »
the charcoal canister?
Offline ian007miles
Re: Silicone piping
« Reply #4 on: 28 January 2011, 00:24 »
Yes thats the one it's been bugging me what it's called thanx mate. Now we no what it is can I do the pipes ???
Offline bbewekim
Re: Silicone piping (Charcoal canister)
« Reply #5 on: 28 January 2011, 08:09 »
Haven't had it all off mine to check diameters but the bit that connects to the throttle body was 8mm. I just used silicon hosing and it's all fine :)
Offline ian007miles
« Reply #6 on: 28 January 2011, 09:58 »
So I can use the stuff u can buy off of the roll then? It's just I've got loads of it in my shed lol
