Author Topic: removed the dump valve  (Read 1938 times)
Offline golf1.8t
« on: 25 February 2005, 15:45 »
ive removed my dump valve but the engine managment light still comes on
DUBBIN FOR LIFE:
Offline topher
  • Administrator
  • fully functioning
Re: removed the dump valve
« Reply #1 on: 25 February 2005, 15:58 »
you need to get the fault code cleared with vag diagnostic software, or just disconnect your battery for 10 minutes (remember you'll need the security code for your stereo)
Offline dubvrs
« Reply #2 on: 26 February 2005, 15:31 »
Disconnect your battery for a couple of minutes and that clears the fault codes.
Had the same on mine when a boost pipe sheared off. Replaced pipe but still no boost. Disconnected battery and all ok.
Offline golf1.8t
« Reply #3 on: 04 March 2005, 18:50 »
ive had the light turned off and code cleared but its come on agian  its  says  bank1 systems too rich
DUBBIN FOR LIFE:
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 04 March 2005, 18:59 »
did you refit your old diverter valve properly ? check all the hoses to it are tight, especially the little vacuum hose, follow that one along its entire length and check for splits.
