Author Topic: Car cuts out when on idle  (Read 1692 times)
Offline storky
« on: 25 January 2011, 08:50 »
Morning guys,
The missus has a gti 8v. Battery was flat this morning. Gave it a jump but now the car will not idle. Starts ok but as soon as foot comes off accelerator it dies! Any ideas, thanks.
Offline javalin
Re: Car cuts out when on idle
« Reply #1 on: 25 January 2011, 09:28 »
what engine is it?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline polo6n222
« Reply #2 on: 25 January 2011, 09:30 »
could be the relays or thortle body is dirty
my money is on it being an agg engine
Offline storky
« Reply #3 on: 25 January 2011, 09:40 »
its a 1996 n?
« Reply #4 on: 25 January 2011, 10:11 »
seriously people, use your eyes before starting yet another thread. 1 already up on the first page:
http://www.golfgtiforum.co.uk/index.php?topic=179425.0
Offline storky
« Reply #5 on: 25 January 2011, 11:51 »
Your comments are appreciated rubber, however the other post does not seem the same. My fault is not when car is warm, nor when clutch is depressed. Open your eyes bud  :grin:   :wink:
« Reply #6 on: 25 January 2011, 12:09 »
yet the solutions are the same. if you did a search you would have found elevnty billion other threads with the same problem and the same old list of things to try ;)
Offline storky
« Reply #7 on: 25 January 2011, 13:03 »
Ok cheers mate. I did trawl through the searches, most of them said try the search function!!!!
Offline Khare
  • The bear that khares
« Reply #8 on: 25 January 2011, 13:25 »
For a reason.
Because this topic gets covered at least once a day.
Offline polo6n222
« Reply #9 on: 25 January 2011, 16:28 »
dose the oil light flash when it cuts out atall
