Author Topic: Car cuts out when on idle  (Read 1683 times)
Offline storky
Re: Car cuts out when on idle
« Reply #10 on: 25 January 2011, 16:45 »
I think it may have done actually!!
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #11 on: 25 January 2011, 18:12 »
Did the wheels rotate just before it stalled?
Offline Khare
  • The bear that khares
« Reply #12 on: 25 January 2011, 18:37 »
dose the oil light flash when it cuts out atall
That's normal though, because the engine looses oil pressure.
Try it, stall the car, you'll see the light flash.
Offline clivusdel
  • Mk3 Golf GTi 8v
« Reply #13 on: 25 January 2011, 19:20 »
has it got petrol in it?????????????
Offline storky
« Reply #14 on: 25 January 2011, 19:45 »
Turns out it needed a new battery  :grin:
Problem solved.
Offline javalin
« Reply #15 on: 25 January 2011, 21:47 »
good news - sometimes just solving the problem you can see works!
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline polo6n222
« Reply #16 on: 25 January 2011, 22:03 »
the reason i asked about the oil light i had the same prob on one of my cars the relay was at fault car would cut out with oil light flashing
« Reply #17 on: 25 January 2011, 23:40 »
Problem solved.
Is the alternator charging all ok.  :smiley:
« Reply #18 on: 26 January 2011, 10:12 »
as above, does battery warnign light come on with ignition then go out once started? if not its the blue wire from the alt, follow it from alt across to the single pin plug near the starter
