Author Topic: head unit problems  (Read 2322 times)
Offline chubbs111
head unit problems
« on: 24 January 2011, 16:55 »
hi guys  ive got a couple of problems i need help with    i bought a 93 gti yesterday with no radio but the wiring loom is intact and it doesnt look like its been messed with       i fitted a jvc unit  (came from my old car perfect working order)   with the red connected to red and yellow to yellow it switches off with the key but doesnt hold memory   if i put red to yellow and ellow to red it holds memory but doesnt switch off with key             2nd prob    ive got no radio reception ive traced ariel cable to passenger side footwell were the cable goes into a plastic inline i think must be an ariel amplifier   cable looks ok     however if i remove the ariel from radio and gently put small screwdriver in the hole i get a reception      any ideas please
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
Re: head unit problems
« Reply #1 on: 27 January 2011, 02:33 »
of course you would need to remove the key completely to see that it switches off...cus i no with the VWs, even when ignition is switched off...so long as the key is still in the barrel after turn off..the ignition is technically on for the radio...or to test that theory...remove the key completely...and use ur finger and press and hold the barrel in where u wud normally put ur key in...its almost like a button! Most cases with VW's is that the OEM aerial loom tends to b quite weak with aftermarket or none original radios. So you are required to purchase an additional aerial signal booster which is almost like a cylindrical affair with a blue wire loose hangin off it to attach to the remote wire of the new radio to send power to turn the little aerial amplifier ON and then work its magic. Common issue with VWs n Audis. Altho a lot of em are ok without this booster too so its more a game of chance dependant on the car itself i find.
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
